Old 07-11-2012, 11:01 AM
geberhard's Avatar
geberhard geberhard is offline
Originally Posted by Z06vette View Post
... I usually just remove the master & disconnect it from the pedals & leave it attached. I'm doing a 68 bird vert with LS1/4L60 right now. I'm almost done, but have put about 10 miles on it so far. Look forward to watching you progress on the swap!
Winner! That is what I ended up doing, still pretty tight space to push through firewall but worked in less than 10 minutes ugh! Have a link for the build?
Rene, LED's look sweeet!!!!
Old 07-11-2012, 10:14 PM
FETorino's Avatar
FETorino FETorino is offline
Click on the green film strip icon
It gives you a pair of UTUBE in [UT].
Paste the end of your address after the = sign (in your case, UACCQ-HWfuM&sns=em) in between the [UT][UT]
Rob in SoCal
Old 07-12-2012, 04:59 AM
68firebird's Avatar
68firebird 68firebird is offline
thank you Rob!!
Rene P.
my 68 firebird low budget build----> https://lateral-g.net/forums/showthread.php4?t=26675
Old 07-12-2012, 01:24 PM
Steve68 Steve68 is offline
oooohh ahhhhh, nice colors!!
Old 07-13-2012, 05:46 PM
Stilo Stilo is offline
Nice bird
Old 07-16-2012, 04:33 PM
68firebird's Avatar
K Guys, I really need some help. Got my master cylinder and prop valve in today, supposedly this is supposed to fit my car, but the prop valve hits the fender well bracket. I'm thinking I'm gonna have to fab up some kind of bracket, is this the best idea? nothing ever goes easy!!!!!! I also need new brake lines, as these all connect in a different spot compared to the last prop valve.
can this prop valve be turned and mounted with the side facing down? thats the way the original one was. Please help!!!!!!!!
Would it be ok to mount the prop valve like this? I don't know if mounting it differently effects performance.
Rene P.
Old 07-16-2012, 04:39 PM
geberhard's Avatar
Rene,
I normally skip the prop valve bracket altogether.
Gui
Old 07-16-2012, 04:45 PM
Z06vette's Avatar
Z06vette Z06vette is offline
I'm using a booster on my 69 camaro & 68 bird so the prop is a lot farther forward. I've havent seen that master used right up on the firewall before. Maybe do a little tube bending to get the bend closer to the master? I bent a few of my lines so they would line up with the master. The prop bracket was a pain to use but I bent the lines to mate up to it. Scott
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 07-16-2012, 05:02 PM
68firebird's Avatar
Originally Posted by geberhard View Post
Rene,
Gui
you just let the lines hold it in place?
Rene P.
Old 07-16-2012, 05:03 PM
68firebird's Avatar
this master supposedly works with manual brakes, in fact they say that because it has a 1 inch bore that it makes the manual brakes feel pretty good. I'm feeling kind of deflated at the moment. I was really hoping for a simple plug and play kind of thing, but what was I thinking!!
Rene P.
