Old 08-18-2012, 04:12 AM
fleet's Avatar
fleet fleet is offline
Originally Posted by imjustjames View Post
What Modifications are needed to use an 05 GTO center console with otherwise stock interior?
You may want to re-post that question under the interior/electrical section of this site.
https://lateral-g.net/forums/forumdisplay.php4?f=40
Old 08-18-2012, 06:28 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
..... Well see if it stops there....haha
Keep all the receipts because it won't stop there. It never does.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 08-18-2012, 01:47 PM
imjustjames imjustjames is offline
[QUOTE=compos mentis;431219]You may want to re-post that question under the interior/electrical section of this site.
Thank you Sir, ill ask there. Still getting used to the different sections
Old 08-23-2012, 02:10 PM
Default Some Work Down.. More to go!
As of today, the cage is out, The car is Dyno matted, and Carpet is done. The Gto center Console is installed, (although it needs to be added onto to get it more flush with the dash). The Rear seats were added in, they are just standard 68 Camaro seats, The Front Buckets are some Nice summit imitation Leather.
Im getting close to getting here finished with first phase cosmetics. Once the door panels get here and are installed. The car will head to Paint.
When It gets back, I am going to Reroute the engine bay wiring and give it a flush look. I'll post some pics when I can.
Old 08-29-2012, 03:26 PM
Default Some more done
Interior is almost to where I want it. Just deciding if I want any audio equipment or not. Just ordered a custom shift boot, and the trim for the gto console to cover the trans tunnel. Had to grind some pieces away from the standard GTO console in order to get it to sit right on the trans tunnel. Interior is getting to where I'm almost content. As soon as the seats are bolted down and I get the console how I want it, I'll post some pictures.
Old 08-29-2012, 03:28 PM
Default What do you guys use to coat the inside of your trunk?
What sort of spray do you recommend for the coating inside your trunk to have a good look and a good coat?
Old 09-22-2012, 11:27 AM
Default Almost through with Paint
Car will be out of Paint on Wed.
Then back to installing the finishing touches on the interior.
She is coming along good, I'll post some pictures ASAP
