Old 08-25-2012, 10:48 AM
ProTouring442's Avatar
Default Mandrel Bent Frame Pieces
I found a place that sells Mandrel Bent Square Tubing sections, but now that I would like to order some, I cannot seem to re-find it. Anyone know a source?
Thanks!
Bill
Never met a man with real talent who felt the need to deride the efforts of other.
Old 08-25-2012, 11:56 AM
Ron in SoCal's Avatar
Pretty sure Art Morrison will do that for you Bill.
Ron in SoCal
69 Camaro in progress
Rick D's Avatar
Rick D Rick D is offline
Here's a couple, I have talked On the Ground in the past but never purchased anything from either but I will soon.
http://www.onthegroundperformance.co...ramerails.html
http://www.autoweldchassis.com/spec.ivnu
Rick
Old 08-25-2012, 12:31 PM
wellis77's Avatar
wellis77 wellis77 is offline
I bought 2x4 mandrel bent frame rails from Art Morrison, bent to my specs. Everything came out perfect! I couldn't get Autoweld to return my calls.
Will Ellis
Project SCUD, 1969 Dodge Dart Swinger, 1/2 Dart / 1/2 Viper
Old 08-25-2012, 02:14 PM
This sort of thing, but mandrel bends?
http://www.welderseries.com/blog/onl.../frame-curves/
Ah-ha! Yes!! I now see them on the Art Morrison web page under "new products! Wooohoo! Thanks guys!!
From their website:
90 Degree Bends for Fabrication
Builders have asked us to custom make small sections of 90 degree mandrel bent tubing for fabricating pieces and parts on a chassis. The "hard way" bends are on the 2" tall section, while the "easy way" is on the wider 4" section. Prices are from $60.00 to $65.00 each. Due to size of item $7.50 box charge added at time of order.
Choose from one of the following once added to cart.
Prices:
(A) 30" Easy-way 2"x4" 90 Degree Bend $60.00
(B) 36" Hard-way 2"x3" 90 Degree Bend $60.00
(C) 36" Hard-way 2"x4" 90 Degree Bend $65.00
Thanks!
Bill
Old 08-25-2012, 04:20 PM
dhutton dhutton is offline
http://autoweldchassis.com/spec.ivnu
Old 08-25-2012, 06:10 PM
coolwelder62's Avatar
Don't bother with Autoweld.I tried for weeks to get them to get me a quote.They said they were just to busy to quote it.
Old 08-25-2012, 08:16 PM
ccracin's Avatar
ccracin ccracin is offline
Can't go wrong with the folks at Morrison. If they can't do it, it can't be done!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 08-26-2012, 10:56 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
Or you can try Chassisworks
http://www.cachassisworks.com/cac_products.html
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
