Old 09-24-2012, 08:39 AM
GrabberGT's Avatar
Uhm I forgot
Rear's
18 x 10 - bs 6.75"
BFG KDW2 - 295 35 18
Note: The DSE Mini Tubs allow me to bring the wheels in way further then a stock set up and yes these tubs are well worth the money.
Front's:
18 x 8 - bs 5.75"
BFG KDW2 - 255 35 18
Special Modifications
Ride Tech Upper & Lower Arms
Mcgaughy Drop Spindle
1/4 Spacer
Bear Tracker Tie Rod Ends ( modified spindle mount )
Just a thought for you. Im running the 295/35-18 and 265/35-18 and wish I would have gone with a 275 on the front. The 265 looks a little rubber-bandish from some angles. The sidewall height isnt what I am used to seeing.
Chris
Its not a Vega!!!!
The Following User Says Thank You to GrabberGT For This Useful Post:
syborg tt (12-16-2018)
  #412
Old 09-24-2012, 08:42 AM
syborg tt's Avatar
Hi Chris,
I may end up swapping to the 275 up front like you've done. I really like that tire combo. Plus the 26" tall profile might help me not bottom out so much
ps - your car looks awesome and I love the front spoiler and we need more pics of it !!!!!!
marty-mj
Old 09-24-2012, 09:03 AM
Ricochet's Avatar
Ricochet Ricochet is offline
and that little mini-truck known as Syborg TT
Oh...Now you call it a mini truck
Looking good Marty!!
Brent
Old 09-24-2012, 09:07 AM
syborg tt's Avatar
I am pretty certain Rodger & Kenny can't fit in the car. So we can call this my mini car maro
marty-mj
Old 09-24-2012, 06:28 PM
syborg tt's Avatar
2nd Chance Camaro - To 335 or not !!![
2012 09-24 Update - To 335 or not !!!
www.2ndchancecamaro.com
Evening all,
There has been a lot of progress on the car and I am playing catch up on the posts.
So here are the two tires side by side. 335 on the left and 295 on the right.
Since the goal it actually drive this car I am pretty sure I am going to be using the one on the right. However I will still make sure the bigger 335 fits under the car.
We did however find another use for this tire. Yep it makes kid smile !!!
Pictures hosted by www.garagescene.net
marty-mj
Old 09-24-2012, 06:37 PM
coolwelder62's Avatar
Marty,Very Cool.I remember when my boys would fit inside a tire.
Old 09-24-2012, 08:05 PM
Either tire will look killer on there.
Old 09-25-2012, 07:37 AM
srh3trinity srh3trinity is offline
I like the idea of having the option of running either. I am glad you put a picture up of a 295 because I was planning on staying around that size with my Firebird. It gives me some perspective.
Stephen
Old 09-25-2012, 08:09 AM
ironworks's Avatar
The sidewall height of the tire is more determined by the Profile or series of the tire and 265/40 would give you a better proportion that you wanted.
To do the math it goes like this
265 mm x .35 = 92.75 mm sidewall
295 mm x .35 = 103.25 mm sidewall
275 mm x .35 = 96.25 mm sidewall
but a 265/40 would be 265 mm x .4 = 106mm
So if you are maxed out on width go to a taller profile in the front then the rear. The profile number is just a percentage to the bigger the difference in width from front to rear the bigger the profile change needs to be. It is a pet peeve of mine to not have the same profile unless you trying for a big a little tire combo. If we were running a 335 rear tire and a 275 front tire the math would look like this.
335 mm x .30 = 100.5
275 mm x .40 = 110.00
or
285 mm x .35 = 99.75
Hopefully this info is slightly helpful. I have to work up tire combos all the time and it can be tough to get a perfect matched set as far as profile, compound, width and matching tread pattern.
Cool Maverick
Old 09-25-2012, 09:03 AM
syborg tt's Avatar
Your welcome - glad I can help
Great Info Rodger - Thank you
and your right that is a bad ars Maverick
or
Cool Maverick
marty-mj
