Old 10-11-2012, 10:20 AM
lutzy lutzy is offline
Default Which crossmember for tko600 and lowered body mounts?
Just bought a tko600 kit (69 Camaro) from a vendor and the crosmember that was included was 5/8" thick where it bolts on top of frame between the body. The problem is that the crossmember that I took out(PITA!) was only 1/4" thick I had to hammer it out. So theres no way i'll get the 5/8" one in. I knew the previous owner replaced the stock body bushings for the DSE body mounts which I think lowers the car 1/2". Im sure plenty of people have a simliar setup and would like to know what kind of crossmember you use for this application?
Old 10-13-2012, 12:40 PM
You can chop the ends of the x member so it fits between the frame rails then weld in 2 sections of 3/16" bent at 90 degrees with holes in it to mount the modified x member.
Just drop down to the appropriate amount to remove. If you have to you can shim the trans mount to get your angles dialed in.
Old 10-13-2012, 09:33 PM
would be a good idea but the crossmember I have is aluminum. thanks for the idea though...
Old 10-13-2012, 10:55 PM
It needs to be 2 or 3 piece. I went through this on mine. The body and frame are just to close together to slide a one piece in the slot.
Old 10-13-2012, 11:39 PM
can you point me in the right direction??
Old 10-14-2012, 12:02 AM
where is your location?
Being aluminum makes it an easy job.
Vince
Old 10-14-2012, 07:56 AM
Im in South East Florida..near West Palm Beach
Old 10-14-2012, 01:43 PM
There are several shops in you neck of the woods that can handle this.
Prodigy, Too much....
is this your cross member?
Have you set up your exhaust yet?
Old 10-14-2012, 03:27 PM
Yeah that's my x member.. I'm about 2 hrs from Frank, but it seems like he has alot on his plate right now...
As far as exhaust, I have a magnaflow xpipe setup.
Old 10-16-2012, 11:17 AM
looks like the vendor stepped up and will be switching out the cross member for a 3 piece
