Old 10-21-2012, 08:21 PM
Rick Giles's Avatar
Rick Giles Rick Giles is offline
The DSE suspension is complete with the exception of the rear sway bar. Also need larger front and rear tires but have to wait for the body to be set to check for fitment. Sure is good to see her sitting on all four tires!
Old 10-21-2012, 08:32 PM
coolwelder62's Avatar
Rick,As alway's lookin great. I installed a 9in. housing in my 66 chevelle build.At ride height it look's like the upper link bracket's on top of the housing might bump the trunk floor.Have you mocked up your's.
Old 10-22-2012, 05:59 AM
Rick Giles's Avatar
Thanks! I had it mocked up with a different suspension and the car was sitting much higher. Might have to make a couple of pockets for clearance. Hope not though. Thanks for the heads up!
Old 10-22-2012, 06:12 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Awesome!
Old 02-17-2013, 06:52 AM
Rick Giles's Avatar
A visual update of the last few months. Sure is nice to be done with the dirty work!
Old 02-17-2013, 06:57 AM
Rick Giles's Avatar
A few more...
Old 02-17-2013, 08:52 AM
Rick I'm really lovin your chevelle.JET-HOT also did my reworked header's.Awesome Company and Quality workmanship.I hope my chevelle turns as nice as your's.
Old 02-17-2013, 09:04 AM
This sure morphed into a big project. Great job.
Old 02-17-2013, 05:55 PM
g356gear's Avatar
g356gear g356gear is offline
Originally Posted by Rick Giles View Post
A few more...
Looks awesome! Where did you source your manifolds from?
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 02-17-2013, 08:55 PM
66138 66138 is offline
Default What size rims ?
Great project ! What size rims and backspacing do you have there ?
https://picasaweb.google.com/1036140...eat=directlink
