Old 11-12-2012, 10:15 AM
frojoe's Avatar
frojoe frojoe is offline
Hey John,
I have it up for sale to move over to the Ridetech stuff. I like that the Ridetech coilovers isolate the spring on the shock body, so it no longer uses the frame's spring bucket to contain the spring, as well as the adjuster knob being on the top for easier adjustment from inside (front end is so low I can't reach the QA1 knob without jacking up the front). Also, the ride quality of the Ridetechs. Got a ride in Resurrexion a while ago and was blown away with the stability yet suppleness of even the single-adjust Ridetechs.
Joe
1972 Nova with twin 6466's and T56 Magnum in the works. Speedtech, Ridetech, Wilwoods etc. Swap thread --> http://ls1tech.com/forums/showthread.php?t=980909
Old 12-26-2012, 03:04 PM
LS1NOVA LS1NOVA is offline
Id recommend notching the framerail with those tubs. When you have the piece cutout, you can weld in a nice reinforcement on the inner frame rail.
Note: Ive had 335's on mine. Looks killer. Do it!!!
Nate
71 Nova. "The Green Machine" April 11' PHR
Old 12-26-2012, 03:24 PM
Bsinclair Bsinclair is offline
very nice....
Old 12-26-2012, 04:40 PM
Blake Foster's Avatar
Originally Posted by frojoe View Post
Ryan.. I'm not if I want to cut into the frame rails.. from a thread somewhere that I saw, there had to be significant cutting, to the point of the framerail being less than 1" thick, to fit a 335.
A stock Nova tub will hold a 275 comfortably at my ride height, likely 285 as well if the BS was increased slightly and possibly a higher ride height. From what I've read, up to 315 can fit if the wheelwell tub is widened up to the outboard side of the rear frame rails. To go wider than 315, the tire will interfere with the framerail so the framerail will have to be notched inwards and the tub widened even more so..
FYI The 72 we just finished at Speedtech had the standard minitub and it has 335/35/17 Michelin psII on it with no issues. i will switch to a good 335 30 /18 PS2 is the only one available, when it is time to replace the tires on my
nova
Blake Foster
www.speedtechperformance.com
Old 12-26-2012, 06:12 PM
frojoe's Avatar
Thanks Blake that's really interesting to know... I have a similar rear ride height to yours and it's interesting to know this.
Only will be able to tell once I've cut out the stock inner tubs and have a tire to mock in there. I got the DSE mini tubs sitting in the garage but have yet to find time (or consume enough liquid courage) to start cutting into the car. Maybe this weekend though...
Joe
Old 12-27-2012, 07:56 AM
next69 next69 is offline
How will running the 335's affect exhaust packaging between the tires and fuel tank? I would love to shoehorn some 335's under my 70 Nova!
Old 12-27-2012, 08:54 AM
frojoe's Avatar
I already dog-ear'd the gas tank for ample exhaust clearance while the tank was brand new and I was modifying it for the in-tank pump sump setup.
Joe
