Old 11-07-2012, 09:32 AM
huggerz's Avatar
huggerz huggerz is offline
Default Might take the plunge. But have some questions.
Hey fellas. Lookin at puttin a 5.3 into a 69 Camaro. But I have some questions first.
1. Can i use my 700r4 with a drive by wire tb?
2. If i cant will a 4l60e or 4l80e fit in my trans tunnel with out hacking it all up?
This is kind of my deciding factor. If i cant use my 700r4 or have to do something with the trans tunnel to run a 4l60/80, I might just get a ZZ4.
Aaron
69 Camaro
Old 11-12-2012, 07:18 PM
Z06vette's Avatar
Z06vette Z06vette is offline
700R will work but you will need adapter flywheel w/spacer. Will also need to rig up a way to hook up the TV cable, which may be a problem w/DBW TB. The 4L60E is same size as 700R. Not sure if the 4l80E fits, I have not tried that swap, but others have. Best scenario would be to get 5.3 w/trans & wiring. Sell all your old stuff. Will be easier & probably cheper in the long run.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 11-13-2012, 05:02 AM
WILWAXU WILWAXU is offline
4l60 is a newer transmission based on the 700R4, the 4L60E is the electronic version. The newer 4L60E's that came with LSx had a separate bell housing, which may cause slight fitment issues, but many here have used then in 1st Gen cars.
The 4L80E is a different animal all together.. larger, but also a lot more durable. It's traces it linage back to the TH-400.
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 11-14-2012, 02:11 PM
andrew69_04 andrew69_04 is offline
I would recommend the 4l60e as well. we had one in our 69 for awhile with no issues. It was a tight fit but it was doable.
69 Z28---awaiting DSE 4 link kit
79 Z28 LS2 4L65e swap--going in for paint!!
Old 11-14-2012, 03:23 PM
Sparks67's Avatar
Sparks67 Sparks67 is offline
4L80-E fits in my 67 Camaro, and there is no modifications to the tunnel. The 4L80-E was rather tight, but fit in fine. You might ask Steve of Twist Machines, but the 4L60-E should fit fine too.
Jeff
Old 11-27-2012, 12:27 PM
huggerz's Avatar
Well. I got a little carried away during the searh for a engine. I orderd a 2002 ls1 with a 4l60e. I got everything with it. Let the finger pinching and head scratching begin.
Thanks for the replies fellas, Im sure I will have many more questions.
Aaron
69 Camaro
