Old 12-16-2012, 02:02 PM
It looks great, coming together nice.
Old 12-16-2012, 02:28 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Some major work going on here. It's starting to come back together nicely. Keep up the good work!
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 12-22-2012, 10:45 AM
Lous69 Lous69 is offline
When I first saw the new body panels clamped to the car it made me nervous.
I guess you could say the body lines and gaps were in the same zip code from part to part but it was more than obvious a lot of massaging would be needed to get everything better than new.
Kevin and the rest of the gang at V8TV didn't seem at all surprised that the trunk lid did not match the tail panel which also did not match the quarters very well.
They first reminded me that in 1969 cars varied from each other when they left the factory plus over 40 years of use and abuse leads to a lot more variations in any one car.
They assured me they have seen worse and that they knew how to cure all the issues we were looking at.
Of course the goal of this build is to make everything fit even better than when the car originally left the factory.
Look at the "new parts just clamped together" body line mismatches between the deck lid, tail panel and quarters...
Here are just some of the tricks Nick and Nathan had up their sleeves..
First the desired deck lid gap behind the rear window was set. (Those miserable corner gaps will be fixed later by reshaping the deck lid corners).
The quarters were clamped on while paying close attention to the door gaps. (The door gaps will be further improved later too).
They decided it would be worth transplanting the rear drip rail from the original tail panel to the new tail panel in order to get the best results. Here it is tacked in place after numerous trial fits.
Since we wanted a tighter than new gap between the deck lid and the tail panel across the back of the car, the corresponding height of each quarter panel had to be adjusted.
To do that, each side was measured and marked where the new folds needed to be in order the effectively "lower" the quarter panels to the height of the deck lid.
A little cutting and notching was then done to allow reshaping things as needed to achieve the proper gap between the quarters and the tail panel.
To make the body lines and gaps between the tail panel and the quarters match up better required similar marking, notching and reshaping was needed.
It all started coming together better and better..
Now that things were looking good the tail panel could be prepared for final welding in place.
After a little more detail work, the quarters will be removed once again, prepared for final welding and then reinstalled permanently.
Old 12-22-2012, 11:06 AM
Ketzer's Avatar
Ketzer Ketzer is offline
Amazing to watch but I don't think you are supposed to be giving away all those "secrets"....
Jeff-
Old 12-22-2012, 11:54 AM
We'll have to see if Kevin reels me in for showing some of their "secrets" but generally, V8TV's whole philosophy is to show people how things work in the real world so they can either better do the job themselves or at least know what to expect in work they have done by others.
For me, it's one thing see their secrets but quite another to be able to replicate them. It takes serious skill and experience like Trevor, Nick and Nathan's to actually execute.
Glad you are enjoying the tread!!
Old 12-23-2012, 02:48 AM
Jgpclone's Avatar
Jgpclone Jgpclone is offline
looking good
Hi my names is danny and im a "hp junky"
2006 tbss stock dd
1969 camaro project
2004 scsb silverado joe gibbs clone
Old 12-23-2012, 01:15 PM
cencalc6 cencalc6 is offline
Nice Job on the Tailpanel,coming out very nice
Old 12-23-2012, 05:50 PM
Sonar Chief's Avatar
Thumbs up
The car is coming together nicely.... especially like the close up shots of the right way to fix things.
I will be adding quarters this summer so it's nice to see how it's done.
Thanks!
Old 12-23-2012, 06:49 PM
Very nicely done, I wish my tail panel fit that good.
Old 12-23-2012, 09:25 PM
V8TV's Avatar
V8TV V8TV is offline
Thanks for the kinds words, and thank you Lou for continuing to post the story and the pics, your doing a great job!
We're not concerned with divulging any "secrets", like he said, we just want people to see what goes into these kinds of projects so they know what to expect on their own, or aren't blindsided if a shop tells them that their parts didn't fit perfectly straight out of the box.
We've been working on the cage and some additional sheet metal work, and I'm sure Lou's updates will continue to do a great job telling the story. We've also got more videos coming soon!
Kevin Oeste
V8 Speed and Resto Shop
V8TV
Muscle Car Of The Week
V8 Radio Podcast
All about us:
https://www.v8speedshop.com
