Closed Thread
Old 12-19-2012, 09:32 PM
FETorino's Avatar
FETorino FETorino is offline
I was thinking today how I got myself into this mess.
I did a search on the FE forum and found the post from the day I bought my project.
The weekend after I brought it home I tore it down and found out the previous owner had set 20 thou of lash as if it was a solid, BUT it had hyd lifters No wonder the lifters clattered like they did. Looking closer I saw the stock springs were on the verge of coil bind so good thing he didn't preload the lifters or I probably would have dropped a valve.
Better to be lucky than good.
O/T Fe road tripMarch 18 2006 at 2:42 PM
Rob (Login fefairlane)
I have a sickness. 60's Ford muscle cars. I keep looking at them, watching the auctions on e-bay, looking in the recycler,craigs list this site. I own a 67 GTA convertible Fairlane with a 390.
I couldn't help myself though.
I was watching a 69 Torino on e-bay in the San Francisco area and the same day my boss told me I needed to go up there for work.
I bid and won the car and with a one way ticket I was off. after looking the car over and paying for it I set out around 5:15 from downtown SF. Several hundred miles ahead of me in a car I've never worked on with only a small assortment of tools I brought for emergencies I'm off.
Exhaust leaks, check, Holley dominator manifold with double pumper, check, well at least the oil is clean and the coolant in the radiator looks good. Hey the gas gauge, wipers, lights and speedo work.
Cruising down the 101 (to avoid the possible snow on the grapevine, did I say I was driving to Orange county in SoCal?) I realize why I was embarking on a plan so stupid.
The 390 purred, although the exhaust leaks ruined the melody when the throttle was applied. Not a sound form the toploader or nine inch out back. One finger on the wheel or hands off and the car still tracked straight. there is something about a FE and a stick shift. The sound, the performance (if it had the right combo, mine currently doesn't). Suddenly the plan seemed great. Somewhere around Salinas a CHP officer pulls me over because my taillight are too dim. He send me on my way "that's a nice car be careful I'd hate to see someone rear end you". A stop at the next offramp and some sanding on the connections get me a better ground and better taillights.
The oils pressure and temperature are constant and good. The factory tach (yes it has one) doesn't work. I notice the wire isn't hooked to the coil but the connection is corroded so that will have to wait till I get home. I really shouldn't drive it home. The exhaust leaks and some lifter chatter tell me I might be using the last the motor has but if that is to be oh well, I will rebuild it sooner. Some Lucas oil stabilizer for the rest of the trip home (Not a true solution but a possible band aid for a tiered motor with some dumb add on parts).
Around 3:00 am I pull in to Tustin. Several hundred miles behind me. The exhaust leaks seem worse. the lifters sound like solids. I may have cooked the motor? well I planned on a tear down anyway. I'll fix the leaks, pull the valve covers to check the rocker shafts (and put the stock covers back on, anybody want a deal on some chrome Erson rocker covers?) change all the fluids and asses what I need to do from there.
She started fine again this morning. The toploader shifts nicely. I got her home and I've got one more FE project. 69 Torino GT 390, 4 speed, no console, AC, factory tach, Power disc brakes and steering. a good starting point and a great time driving down the coast with the humm of an FE.
Rob in SoCal
  #522
Old 12-19-2012, 09:41 PM
That was a good read... I was right there in the passenger seat with ya and could feel the drive...
Good find on the lifters.. amazing what people do!
  #523
Old 12-19-2012, 10:08 PM
badmatt's Avatar
badmatt badmatt is offline
Looks great Rob.
Keep it up this will be one hell of a car when its finished. Should put a nice lil whippin on my SB2.
97 Sonoma "NERA": Pile O Sh*t. Literally.
  #524
Old 12-19-2012, 10:28 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Between the chassis and my Dailey pan no wonder Phil said I should turn the car upside down.
It should help me put that 700hp and 630ft lbs of torque to use.
Thanks.
Yea soon it will be in my hands then the progress will Slooooow down
I'll be by to pick you up eventually.
Only 630 ft lbs? My small LS made more than that on it's break in run.
Your pile of parts is becoming quite a nice collection. If only you had known what you were getting into when you bought the car!
  #525
Old 12-19-2012, 11:09 PM
Great story dude!
So how much of it is true?
  #526
Old 12-19-2012, 11:16 PM
67goatman455 67goatman455 is offline
I apparently missed the memo that you were getting a new frame. Unexpected all over my keyboard
1967 GTO, LS2 T56
WILWOOD FORGELINE RIDETECH
$10k Budget driver/ track car
  #527
Old 12-20-2012, 10:23 PM
390 S code 390 S code is offline
Rob
great to see your making progress i have been looking around at some of the auctions myself,my brother is keen on a Torino or a Fairlane .Is there more room between the towers and the exhaust manifolds .My motor build is near complete it is fully assembled ,waiting on the the roller rockers they are coming via santa's sleigh .It has been a long wait .
Mark
  #528
Old 12-21-2012, 10:11 PM
FETorino's Avatar
Originally Posted by badmatt View Post
Looks great Rob.
I don't know about the whippin but it will give it a run for your $$.
Mine will last longer than one season
Great story dude!
Only the part after "I"
You know you just never looked the thread over because of the title. One of their chassis under a 67 Goat with a built 455 Poncho would be pretty sweet.
Rob in SoCal
  #529
Old 12-21-2012, 10:23 PM
FETorino's Avatar
Originally Posted by 390 S code View Post
Rob
Mark
Mark
I see you are getting close on that fasback of yours No more room between the shock towers than your stang. I think you can use Mustang Headers in a Torino/Fairlane.
It will be cool to see that tripower injection in action.
Rob in SoCal
  #530
Old 12-22-2012, 06:14 AM
intocarss's Avatar
Post #522 I was right there with you too, but in disguise.. as I couldn't let my friends see me riding in a Ford
Closed Thread
