Old 03-17-2013, 07:35 AM
Mucker15's Avatar
Mucker15 Mucker15 is offline
Default Lsx swap parts question
I'm pretty sure im going with an 2007 and up lq9 46le swap in my 69 Camaro
Due to family finances I won't be able to afford to get the parts at once so im going to pick off a little at a time.
My question can I add the twin fan 98 to 02 radiator to my current SBC set up?
I know I can add the efi fuel tank with a regulator so that might be my fist step
The 46le is a 700r4 from what i have read can it be made to work with my SBC set up ? ( I apologize if these are dopey questions )
Is it possible to keep the car on the road and do it piece meal ? If so what can I do ? Or should I just amass the parts and do it all at nice
2010 SS L99 Camaro T76 turbo 499/556 NY5THGEN
2007 Trailblazer SS DD CAI
1969 Camaro 350 turbo 350 342 posi rear
Old 03-17-2013, 11:39 PM
kainedogg's Avatar
kainedogg kainedogg is offline
Default Swap
For piece of mind gather all your parts first, enjoy the car & when you think you have everything you need (trust me you will not) start the tear down. Download pics of those who have done the swap before you, save the links & keep them handy. To run the fans you would need a controller & a relay setup. Why waste money when you can put that towards a custom wiring harness which will come with the connectors.
GOOD LUCK
Science flies you to the Moon, Religion flies you into buildings
Old 03-18-2013, 09:31 PM
Mucker15's Avatar
GOOD LUCK
Thanks , I'm a bit of aways off need to well my SBC and trans first
Old 03-19-2013, 06:32 AM
Mucker15's Avatar
Will the new trans fit with my stock 69 console ?
Where can I get the harness ? Can I use a stock one ?
Can anyone point in a direction for dash gauges speedo temp tach etc...
Was thinking of looking for an a pillar pod because I want to keep the stock looking dash
As always any help is greatly appreciated
Old 03-26-2013, 09:49 PM
kainedogg's Avatar
Join LS1tech friend. Then don't post your questions, instead just search the threads. You could burn up a weekend looking through all the swap info there. You car swap is pretty common.
Old 03-27-2013, 10:18 AM
The 4l60 fits no problem with the right motor mount adapters and trans mount. We sell a kit that works nice with the stock subframe, I can always help you out with that.
You might have to fold a bit of the pinch weld at the firewall.
Shiftworks makes a detent kit for the stock console shifter, along with a cable, that works with the 4l60. This is what you need!
The fans work, you might have to fab up some mounting tabs. I recommend a Dakota Digital fan controller unless you are using a GM computer and conversion harness that is setup to run the fan relays for you.
Tyler
HPI Customs
Manitoba, Canada
www.hpicustoms.com
Old 03-27-2013, 05:32 PM
jazz2069 jazz2069 is offline
Default Lq9
If your looking for that new of a lq9 (2007), just go with a ly6 for about the same price.
