Old 05-30-2006, 02:54 PM
Steve68 Steve68 is offline
I'll add myself to the concensus, look great!
Old 05-30-2006, 06:38 PM
Blown353 Blown353 is offline
I'm making some custom hubcentric adapter rings tonight out of 6061-T6 barstock (the wheel centerbore is an oddball size and seems nobody has off the shelf hubcentric rings.) Plan is for a .002" press fit into the wheels and a .010" clearance to the hub/axle flange. I'll be hard anodizing them for corrosion resistance.
The wheels work fine as-is being lugcentric (if you take your time mounting them) but paranoia is a driving force behind many of my projects.
Better still, hopefully tomorrow night I'll be taking the knockoff adapters to a friend's shop where I can use his 2-axis NC retrofitted Bridgeport to ball mill a bowtie outline on them. Shhhh, don't tell Mr. Shelby! Just need to draw it up tonight and generate some G-code to feed the machine. I'm open to other suggestions in this department but a slight bowtie outline seems like the logical choice.
1969 Chevelle
Old 05-31-2006, 02:53 PM
Diognes56's Avatar
Diognes56 Diognes56 is offline
Looking good .
David
Old 05-31-2006, 04:44 PM
Jr's Avatar
Jr Jr is offline
Troy,
The wheels look sick!
What would you guess is the average weight of the wheels?
Old 06-01-2006, 12:27 AM
Originally Posted by DJW32
Troy,
Thanks!
Don't know on the weight, I forgot to weigh them prior to mounting the tires. They were nowhere near as heavy as I expected they were. A front wheel/tire combo weighs in at 51lbs and a rear wheel/tire combo was about 56lbs as measured by me standing on my POS bathroom scale while I was holding an example of each.
And a little update, I can now put my paranoid mind at rest.
Inside of wheels as shipped. Oversize centerbore, not hubcentric...
After some quality time with a lathe and some 6061-T6 barstock (plus Alodine conversion coating afterwards for some corrosion protection) we have 4 of these. Sized to be .0015-.002" press fit into the wheels and .004-.006 total clearance over the front hubs and rear axles. The adapters sit .015" below the wheel's mounting pad.
The finished product. Put a light smear of loctite on the adapter rings prior to tapping them in for good measure.
And that's how you make a lugcentric wheel hubcentric.
I also faced off the "SHELBY" logos on the knockoff adapters. I ended up leaving them blank. Looks much better now!
1969 Chevelle
Old 06-01-2006, 08:34 AM
Nice machine work, nice Alodine, did you use the new pen or brush it on,
Old 06-03-2006, 09:40 PM
PairOf69's PairOf69's is offline
how do the 285's sit there, fender lips rolled.? Your car is killer by the way
Old 06-04-2006, 01:15 AM
Thanks! I did the "dunk and swish" alodine method. We had just mixed up 5 gallons so I took a cup of what was left over, enough to completely submerge them.
The lips aren't rolled and I haven't trimmed the wheelwell moldings. Almost an inch to the frame and inner wheelwell and just about 3/4" to the lip/molding-- lots of room. I might roll the lips and try 315/35's when I do paint & body. I'd roll them now but I'm quite certain I'll crack the body filler above the wheelwells.
1969 Chevelle
Old 07-31-2007, 10:37 AM
GHOSTDANCER GHOSTDANCER is offline
Killer Chevelle
Old 07-31-2007, 10:52 AM
61Bubbletop's Avatar
61Bubbletop 61Bubbletop is offline
Lateral-g Moderator
Wheels look great. Nice Choice!
