Closed Thread
Old 06-07-2013, 01:57 PM
  #1012
Old 06-07-2013, 07:05 PM
FETorino's Avatar
FETorino FETorino is offline
14 lb. Done.
Hmm
Maybe a quick check of their website?
http://www.fidanza.com/ItemDetails.a...&eid=70&mkid=6
PRODUCT INFORMATION FOR YOUR 58-70 FORD ALL
ALUMINUM #: 186541
WEIGHT: 14lbs
STEEL #:
PLATE #: 221171
NOTE: external balance weights are included in the hardware kit supplied with the flywheel, includes 11" & 11.5" 3 finger and 11" diaphragm clutch patterns
DESCRIPTION: A Fidanza flywheel can mate with any type of clutch material, including organic, kevlar, ceramic, metallic and sintered iron. We attach the friction surface with military grade aerospace fasteners. The ring gears are made from 1050 steel and are heat treated for durability. The gears are heated then pressed on and secured with grade 8 button screws. We were the first to use a stepped dowel system in most of our flywheel applications. This doweling method ensures that once the pressure plate is installed the dowels cannot be removed because they become locked into place. No chromemoly can compete with the awesome serviceability, strength and superior design of Fidanza's aluminum flywheels. If there was a better material out there, we would be using it.
Image may not be o
Rob in SoCal
  #1013
Old 06-07-2013, 07:43 PM
Ron in SoCal's Avatar
Ron in SoCal
69 Camaro in progress
  #1014
Old 06-08-2013, 03:19 AM
EvoIX's Avatar
EvoIX EvoIX is offline
You do realize which thread you are in?
  #1015
Old 06-08-2013, 06:09 AM
Rick D's Avatar
Rick D Rick D is offline
Opps guess your google search skills need some refining, like picking you hockey team!!
Rob nice trans by the way! So have you ordered wheels yet??
Rick
  #1016
Old 06-08-2013, 09:57 AM
Course I do Jr. That's why I posted those funny little icons. We're all (those that posted) old friends here. With this crew you gotts be able to dish it out as well as take it. That's part of the fun!
I've actually owend a 13lb Fidanza. Never knew they made a 14, but you learn something every day.
Ron in SoCal
  #1017
Old 06-08-2013, 10:45 AM
FETorino's Avatar
It's ok I spelled Fidanza incorrectly
Rick did you make that trip to MI yet?
Rob in SoCal
  #1018
Old 06-08-2013, 12:11 PM
Rick D's Avatar
Next Saturday!!!
Rick
  #1019
Old 06-08-2013, 02:57 PM
Sieg's Avatar
Sieg Sieg is offline
Next Saturday!!!
Build thread starts when the trailer is hooked up!?
  #1020
Old 06-22-2013, 10:18 PM
FETorino's Avatar
Woodward make some really nice steering joints. Luckily I know somebody with welding talent to weld the ends in the CroMol shaft so I can wheel it with confidence.
Notice how sleek the Woodward shafts are compared to the typical Borgenson stuff. A small thing but they are not only functional but Elegant in their design.
Rob in SoCal
Closed Thread
