Old 06-10-2013, 12:35 PM
carbuff's Avatar
carbuff carbuff is offline
I assure you that this site was responsible for plenty of my expenditures during the build process...
Old 06-10-2013, 01:07 PM
It was Rob and Weld's fault... I was an innocent bystander.
Old 06-10-2013, 01:17 PM
RussMurco's Avatar
RussMurco RussMurco is offline
No doubt in my mind, I've been around here long enough to notice who the antagonists are!!!
Russ "Murco" Murray
http://i1339.photobucket.com/albums/...psc7bc7b5c.jpg
"Liquidating excess cash through the automotive hobby!"
Old 06-10-2013, 10:10 PM
FETorino's Avatar
FETorino FETorino is offline
Great news she is finally on the road.
When do the new seats and 335s arrive?
Rob in SoCal
Old 06-10-2013, 10:14 PM
68LS1's Avatar
68LS1 68LS1 is offline
Sure you were
Bryan, very pleased for you.
Roger
68 RS Camaro Convertible LS1 6 speed
72 C10 SWB Stepside, old skool 350 4L60e
71 K5 Blazer 350sbc T350
Old 06-15-2013, 08:45 PM
andrewb70's Avatar
Great to see the car running!
I had a chance to monitor the AITs using a bluetooth adapter for the OBDII port and the Torque application.
When going down the highway, the AIT is about 6-7 degrees above ambient. The temps go up fairly quickly with the car idling in traffic, but they drop quickly once moving again.
Andrew
Old 06-21-2013, 11:54 AM
carbuff's Avatar
Partial update on this. I hoped to update this way before now, but...
After scouring the country, and with help from Weld and Sieg even, I could only come up with a single seat that I wanted to use. I had focused in on the Recaro Cross Sportster as my replacement. This unit has a base without the side bolsters, which was way more comfortable for me. I found one in Eugene, OR, and Sieg was gracious enough to go check it out in person for me! Thanx again!!!
Unfortunately, the packaging and shipping cost on this thing were ridiculous. And even worse, the Recaro dealers were telling me 9 - 12 weeks to get the corresponding passenger side seat, as they are only manufactured in Germany. That wasn't working for me...
So after some soul searching and opening up my options, I have changed my selection to the Recaro Specialist M instead of the Sportster. From what I have read, that seat actually sits a little lower than the Sportster, which will be good for me. The 'M' also has a flat base, which again works better for me. And, perhaps most importantly, Recaro has them in stock, so I can get them quickly. I just completed the order, and they should be here next Thursday. I'm sure Eric will have my mounts made by Friday.
On another front... I spent Wednesday night rewiring my Fan relays. The Holley ECU wouldn't handle the combination of the AC and coolant temp fan control the way I expected, so I needed to add a couple of relays to the system. That was fun, as it was all tucked up under the dash and I had worked so hard to keep it all clean. Thankfully I was able to do it without too much pain (although my back and sides might disagree with that statement!).
Eric has been working on the new front spoiler. That will be mostly wrapped up this weekend. It looks good on the car, and we're working on a design to add a splitter and perhaps some canards which will bolt-on to experiment with on different track days.
Now, about those 335's...
Old 06-21-2013, 11:55 AM
carbuff's Avatar
Andrew
I'll plan to do some measurements on these this weekend. I expect we'll have another 97-98 degree day here, so it will be interesting to see what the ATS shows. I expect some longer duration tuning rides to start dialing things in.
Old 06-21-2013, 12:35 PM
Ron in SoCal's Avatar
Seig is the official Lateral-G seat checker. I have first hand experience with this...
Ron in SoCal
69 Camaro in progress
Old 06-21-2013, 01:48 PM
Sieg's Avatar
Sieg Sieg is offline
Hmmm, this trend is bothering.
Bryan - Too bad that seat situation didn't work out.
