Closed Thread
Old 07-04-2013, 12:29 PM
FETorino's Avatar
FETorino FETorino is offline
I agree with the notion that slapping a tire on a wheel that is to small or on the smaller side of the range may be counter productive. I do however think the biggest tire on the front(Right width wheel) with a reasonable stagger is the best way to go. You notice the Vette/Viper have decreased their stagger and increased front width lately. These old muscle cars are nose heavy and they want to push. You'll find yourself continually looking for an increase in front grip while you own the car. You'll naturally have more lateral rear grip at your disposal which means you will be decreasing rear grip to get chassis balance. I'd say a smaller rear tire would net better side and forward bite due to a slightly more desirable spring rate/shock setting.
Don't get me wrong, I think you can get the car to handle nicely.
I was probably still typing some of the post while yo were posting this. I believe the new Viper is 295/355 so the stagger is pretty similar to my 285/345.
I don't disagree that a 325 out back might not be a better handling choice but we will have to wait and see.
I've got a pretty big mass of sheet metal out back on my car so once I get the motor in it will be interesting to see what my scales tell me.
As I said tires are disposable. It will be interesting when I get out of building mode and not the more difficult part.
Tuning
Edit
And Todd I do appreciate your real world input on this since you lived through it when you built Payback.
Rob in SoCal
  #1152
Old 07-04-2013, 01:08 PM
DBasher's Avatar
DBasher DBasher is offline
Saw this and thought of your build, pretty nice ride. I plan to stop in and talk with him next week and get some details on it, I know he drives it daily.
Dan
Old 07-04-2013, 01:48 PM
Good info and great looking wheels, Rob! I think you're taking the right approach to all this. It's going to be a great car.
  #1154
Old 07-04-2013, 01:59 PM
Track Junky's Avatar
That could start a long topic of discussion in the tire and wheel section, or on this thread. Maybe someone like Ron Sutton will chime in with his thoughts.
First I have limitations to tire size, self imposed limitations because I don't want to do any noticeable modifications to the body of my car.
Starting with that in mind and the black art of tires in general I evaluated the need for steam roller tires in the front. I am by no means an engineer or an expert on this. I have been playing with things that go fast around corners be it Cars, carts or motorcycles for 30+ years so I have some first hand experience and I've done a lot of research on this crap over the years.
First I believe JMO that wider is not the be all end all JMO. I have read and agree that there are benefits to width that go hand in hand with tire height and rim width that dictate the optimum contact patch for a combo. Weight on the tire,more importantly load which is affected by suspension design the cars weight and moment arm all play into it. then you get down to important factors like air pressure adjustment and heat buildup. Just slamming the largest tire you can stuff doesn't guarantee success.
Think of it this way. The contact patch to contact patch is the true track width. If I widen the tires by using more offset I narrow the track width. I also start messing with scrub radius as that patch moves to the inside of the line from the top balljoint through the bottom to the eventual point on the ground.
Im not racing in the Rolex series so no use over-thinking it but I didn't want to go far out on a limb in any one direction.
So I took in some ways a conservative approach and right or wrong a big part started with aesthetics.
I didn't want a 1" or 1.5" outer lip on my front wheel. To me that give a Jiffy POP look of th center popping out of the hoop. JMO I don't like it.
I also didn't want to be stretching or flaring the front fenders.
This also go me thinking about rim width. Why does one guy run a 275 on a 9" wheel and the Nissan guys run one on an 11"?
From all my reading, to a point,not always, wider is better for rim width if it is within the tire manufacturers recommendations.
Look at Porsche they regularly spec tires on Wider than recommended wheel widths from the factory.
My goal was the flattest tread profile for whatever tire size I choose. In reading every .5" of added rim with will add .2" of measured tread width on the same size tire. I looked to match the wheel width and tread with dimension for my chosen tire heights.
I wanted a 26" tall front and 27" tall rear tire to fill my wheel wells and maximize the length of the contact patch and the tires ability to radiate heat.
Out back that was a no brainer. 345 30 19 on a 13" wide wheel. This is the Dodge Viper spec. Michelin built that tire originally for the Dodge Viper. Am I smarter than those companies engineers? No.
So what to match it with up front. Well a front engine rear wheel drive 3400lbs Viper uses a 275/345 combo with a 50/50 weight distribution. I may not get to 50/50 but I'm trying to get as close as possible. I'm also hoping to come in around that weight. Before anyone else says it I know there are more factors than that. To start with CG to Roll center creates a moment arm which actually influences load on the tire as much as total weight. Like I said before I'm not building a Rolex competitive racer so I'll keep it simple.
I borrowed a 275 35 18 mounted on a wheel from Ron, thanks again Ron and a 295 35 18 tire from Brett, thanks bud. the 275 was an easy fit and the 295 ,using my wheel fit tool, was a little big. A 285 should be just right I thought.
Here is where Travis really came through. I had communicated with him a few months ago about a quote for my wheels. I really like the fact his wheels were clean timeless designs and engineered for and used in racing. From my wheelfit measurements I was pretty certain I had a BS measurement and wanted a 10.5" wide wheel wheel.
The 10.5" wheel did two things. The measured tread width of a 285 Mich on a 10" wheel was 10.2" So adding .2" for a .5" increase in wheel width this gave me 10.4" tread width on a 10.5" wheel width. A good match in my mind. It also gave me a 2" outside lip with my backspace measurement to avoid Jiffypop.
In speaking with Travis he said he could build a test wheel to the same specs I thought I needed actually try it on the car. Hell yea. A week alter I had a borrowed wheel made from both new , blem and used parts. Travis sealed it so I could mount and air up my tire.
This was a huge help. I was able to confirm my thinking on backspace, the profile of the 285 on the 10.5 matching that of the rear tire, double checking caliper clearance and getting a real world visual can't be topped.
Tires are disposable items. My car won't be painted before I actually start tuning the set up. I plan on running it in shake down form for a while before I really finish it pretty. If I decide to go wider and do more tweaking on the body it won't be big deal. The 10.5" lets me use a 295 or 305 and still get a good footprint if in the end I feel the 285 is a limiting factor.
I still think the 285 on the 10.5" wheel will give me all the front bite I need if my shocks, springs and bars are tuned correctly.
Gae Last post you accused me of underwhelming you with lack of detail so you are to blame for this one.
I agree to a point. There are alot of variables to take into account when ordering wheel and tire sizes. In our hobby a big one is astetics. Astetics play no part in the way our cars perform yet we are always shooting for how any given wheel design will look with a stepped lip, flat lip, offset, etc. On the same note we are not profesional race car drivers, nor engineers, and it would take a substantial bit of resources to design the perfect wheel/tire design combination for any of our given vehicles so we are left with making our own educated guesses. This is where we start to run into issues with ackerman, scrub radius, etc and is in such our dilemma.
In your case we can anticipate that your tires will be carrying "quite a load" if you will . In turn it's a no brainer that a wider, taller tire out back will be warranted due to the amount of power you will be putting down to the ground.
Now the dilemma......I have chosen a big ass 345 to handle the rear load but what size up front. IMO smart money goes with the widest I can get that will compliment the rears and I dont believe 285's are going to do it. Reason being I used to run 275's all around and had my car neutral. When I mini-tubbed my car and installed 315's out back just for the cool factor the car began to push. I'm still working on getting my car neutral again.
If your adiment about the 285's look into the load ratings for the different heights of the 285's and 345's. Try and choose load ratings that will compliment each other.
Like you said.....tires are disposable........choose wisely my friend.
Gaetano Cosentino
  #1155
Old 07-04-2013, 07:46 PM
FETorino's Avatar
Dan
Wow Dan that is a Cyclone Spoiler II with the Aero droop nose. King of Talladega and Daytona in it's day. Check out the front bumper. Ford actually took a rear bumper and put it on the front to act as an air dam due to it's taller height. Early splitter right there.
Rob in SoCal
  #1156
Old 07-04-2013, 07:56 PM
FETorino's Avatar
Did you raise the nose at the same time? If not the increase in rake alone could have unsettled your previous tune. There is no doubt a change in tires without a change in tune would not likely be an improvement. I bet you'll get it back where you want it AFTER you install that Accusump.
None of these cars (most anyway) will be a compromise. Like Carroll Smith says in Tune to Win (I'm paraphrasing) you could have the best set up on paper and if you don't tune it right it's crap and our could have crap and tune it well and have a fast car.
I remember some guy with a chivy running some fast laps with a 275/325 combo last year. I think I can get the 285 to work good enough.
Rob in SoCal
  #1157
Old 07-04-2013, 10:17 PM
Nose was raised an inch but I dont think that would play much of a factor and was done to get more travel up front. Tires were the same diameter and didn't factor in raking the car. I know what I need to do and the car is now equipped with all the tools I need to get it right(minus the shocks) just need more track time to get it there.
Anyhow, not trying to bust your balls and hope it works out great for you
Gaetano Cosentino
  #1158
Old 07-04-2013, 11:24 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
It's a Ford. Why are you guys spending so much time debating whether or not the front tire will be a limiting factor?
I'm sure Rob will be able to get this Torino faster than a lot of people expect, but I don't think that it will be an easy car to drive fast on a tight course, and I'm not saying that because we're talking about a big car here. Getting the car balanced enough to rotate quickly and be proper fast will require a lot of work. I have no doubt it can be made fast, but I bet it will be much more of a handful to drive than a car with similar sized tire front to rear. On a big course, I bet the tire stagger won't be as big a deal as people think.
I'd argue that on a road course like Big Willow the average driver of a pro touring car like we have, would be more comfortable and being able to push his or her car to faster lap times than if the same car was loose.
p.s. I've driven in some car's *cough* Tom's Mustang *cough* with tires that were too big for the wheels and it was very apparent. You could feel the weight transfer onto a corner and then continue to move out laterally as the sidewall deflected and rolled over. I've never felt that on the 9" /275 combo I have, and much prefer it to the 9"/255 combo I once had.
  #1159
Old 07-05-2013, 09:31 AM
No problem, I'm always happy to share. With an RS chassis, you should be close if the engineering is right. When I sold my car I had it where I could make a few shock adjustments and have a good autocross car and road course car on the same day. That's when you'll know your chassis is really close to where it needs to be for a "Pro Touring" car.
Bottom line, you won't know what you have until the first corner. The tuning was one of my favorite factors in the build process. Making progress you can feel.
  #1160
Old 07-05-2013, 01:03 PM
Ron Sutton's Avatar
The wheels are Formula 43 RAD10 Clubsports. They no provision for centercaps and the I beam lightening on the spokes.
The fronts are 18x10.5 and the rears are 19x13s. I weighed them with my hanging hay
If that scale is accurate, that is a great light weight ... for that size of wheels.
Ron Sutton Race Technology
Closed Thread
