Old 07-31-2013, 10:16 PM
DFRESH's Avatar
DFRESH DFRESH is offline
You're just a step behind Big Red.... they are at Bonneville running their new/modified 598 with..... wait........ 21 lbs of F3 Procharger love.
As if that car wasn't fast enough already---that's sick power with a 598 and 21 pds. I make right at about 1440 with 28 pds and 434 inches--with not so great cylinder heads--and it's not the newer style blowers that are more efficient---I bet he's driving the F3 with one of the CDS drive setups also. All things I will do with my new 540.
Old 07-31-2013, 10:22 PM
67zo6Camaro's Avatar
67zo6Camaro 67zo6Camaro is offline
lateral-g
Old 07-31-2013, 10:27 PM
fleetus macmullitz's Avatar
Originally Posted by 67zo6Camaro View Post
With this torque arm kit, it uses the original front leaf spring pocket to locate the lower trailing arms (also known as lower link arms). These arms are very nicely made and have an easy motion swivel link which proved very effective when I tested the motion of the rear end after mock up.
I am sure Doug will appreciate the value of the arms having an easy motion swivel link.
https://www.youtube.com/watch?v=KQrJ7Jcendo
Old 07-31-2013, 10:40 PM
FETorino's Avatar
FETorino FETorino is offline
One of the other little things that popped up, but was fixed on the fly, was the rear bushing for the arm to pumpkin mount. The tab that was welded onto the rear end was located about 3/16" to narrow. So I did the basic spreading of the tabs.... and I was not happy. It was just to much of a difference to allow a tight fit and good motion without excessive wear. Instead, I pulled the bushing and inner sleeve out and milled them down 3/32nds on each side.
This worked and allowed me to move onto the next issue. For now, because I will be mocking this up one more time before final assembly, I opted to use a smaller threaded rod as a bolt for the rear torque arm mount. That way I'm not banging that bushing in place more than it needs to be and end up messing it up.
Nice write up as always Brett. The thing I'm sure Doug appreciates is you treat other peoples stuff as if was yours. You do things correctly and don't take short cuts just to make a quick buck.
Rob in SoCal
Old 07-31-2013, 11:16 PM
lateral-g
Old 07-31-2013, 11:27 PM
lateral-g
Old 07-31-2013, 11:30 PM
Jtomas801's Avatar
Jtomas801 Jtomas801 is offline
Just for fun, Did anyone notice something "wrong" or "off" in this picture?
The drain Plugs on the rear end?
Jon
_______________________________________________
Jonathan Feltis
69 AMC Javelin - Back in Progress.
Old 07-31-2013, 11:37 PM
lateral-g
The hydraulics haven't been installed yet?
Seems the round part could easily be drawn up and cut on a water jet machine and then welded to the square mounting block? Then powder coat it or paint it...
Old 07-31-2013, 11:40 PM
lateral-g
