Old 09-01-2013, 08:24 PM
makoshark makoshark is offline
Looking good!
The reproduction door latches are fine. I have one on my driver's door. I misplaced my original and so had to get a repop. It works just fine.
I still have to remove the vent bezels from my dash. I haven't taken the time to do that as I've been knee deep working on my console. It's not fun trying to bend 16 gauge sheet metal with a body hammer, bench vice, c-clamps and some 1/4" plate steel. Next week I'm going to build a space shuttle capable of reaching Mars with a washing machine, some juicy fruit and hydrogen peroxide
Old 09-02-2013, 01:16 AM
seankc31's Avatar
seankc31 seankc31 is offline
I thought Chiefs only knew how to drink coffee...you got skills I'm prior navy gse3
Old 09-02-2013, 07:50 AM
Sonar Chief's Avatar
Originally Posted by makoshark View Post
Looking good!
Thanks.
Thanks for your service .... attention to detail and drinking coffee are my top two skills! Now go and get something done that you should have gotten done yesterday .... and double time!!!!
Old 09-02-2013, 12:40 PM
kmdracer kmdracer is offline
Lazy day today. No current project of my own, so am enjoying reading others. Chief, I'm just blown away by your work. Will be following along to completion.
Old 09-02-2013, 11:14 PM
Looking good Chief
Old 09-07-2013, 07:26 PM
Thumbs up Update 9/7
just trying to do it right the first time, don't want to do this again anytime soon! There's plenty more .....
Looking good Chief
Thanks Wayne, been tryin to get somethings done that I can in a day or two, waiting on my drivers quarter and then I'll open up that can of worms
So, I had some hours in the garage today ... been so hot I had to get going at the crack of dawn in order to spray epoxy before it got too hot, wiped everything down taped off the edges and sprayed epoxy.
When it cooled off in the day I put down some Lizard Skin on the inside of the door skin .... in prep for the bonding of the door to the frame, tomorrow? Maybe .... here's some pictures to look through.
Door skin ready for epoxy!
Taped off edges for 3M bonding to frame.
Spraying epoxy finally ....
Lizard Skin on the inside of the door skin ... pretty cool stuff!
She's ready for skins
So that's what I did today .... more tomorrow!
Thanks for looking ...
Old 09-08-2013, 03:17 PM
Post Lizard Skin Lessons
Thought I'd post some lessons learned from using Lizard Skins Sound Control product on my door skins .... in case someone was wondering!
The product is very easy to use ... provided you purchase their applicator gun, and the clean up is with water and soap. Mixed with the paddle provided and applied the first coat yesterday and let it dry, I tried to use the included WET FILM GAUGE to test thickness ... that just made a mess and confused me (simple minded), think credit card .036 thou and they want no less than .040 in two applications. That's the goal.
I used a plastic serving spoon to get it into the pot from the pail ... instead of pouring, cuz when it's done there is product left from the siphon angle and the spoon will get the remains out and back into the pail will little waste.
I used about 45 psi at the gun with a turn and a half on the adjustment tip for the second coat and you can see the texture it left .... more product more stipple, more air more drier dimpled look.
I used a razor blade to clean the edges that had over spray, you can sand and paint the product after it has fully dried ... and that is cool
Just after the second coat was sprayed!
Cured and dry!
Had other pictures but ImageShack is acting up with mongo pictures .....
Any questions, please ask.
Old 09-08-2013, 06:29 PM
Nice!
Old 09-09-2013, 07:29 AM
Tony V Tony V is offline
Chief,
Looks real good and your doing a great job, great motivation for us to keep moving. I'm looking to spray L. skin in the next couple weeks and with your write up it seems something i can tackle without much worries..keep up the great work.
Old 09-10-2013, 06:52 PM
jazz2069 jazz2069 is offline
Default Mini tub
I like the idea of cutting the frame rail deep and widening the tub! More rear tire!!
