Old 09-09-2013, 09:28 AM
elitecustombody's Avatar
Default What's a good source for quality weatherstripping on 79 Formula?
Looking for suggestions . Need good quality weatherstripping for 79 Formula. Not sure who made the ones currently on the car. But they are falling apart being only couple years old. TIA guys.
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 09-09-2013, 11:36 AM
jimbo jimbo is offline
I have always had good luck with Metro Moulded.
http://www.metrommp.com/
Old 09-09-2013, 04:59 PM
Musclerodz's Avatar
My bet on that car they were NOS.
I would use Metro
Mike Redpath
Musclerodz & Customz
facebook page
Old 09-09-2013, 06:36 PM
Mike,you probably remember this car
Trying to chase some of the major problems . Have yet to figure out popping clunking noise from all four corners when brake pedal is pressed or released. . Last year I tightened up rear calipers because they were lose and every nut and bolt I could see . Now seems like noise is louder on front.Maybe it's normal for Baer brakes, but I installed same full Baer kit on 70 Impala not long ago, it never made a noise .Had to notch front control arms because of wrong offset wheels. Car runs way too hot, seals on rear axle are leaking, fuel spills on rear bumper from vent tube and a whole lot of cosmetic problems.
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
Old 09-09-2013, 09:08 PM
glassman's Avatar
glassman glassman is offline
I'm all ears (eyes really) cause i've done OEM and Soft seal and neither seal good around the door on the hinge side....
Old 09-10-2013, 06:16 AM
Streetking's Avatar
Streetking Streetking is offline
I got the seals for my '72 TA from AMES performance. They are excellent..
https://secure.amesperf.com/qilan/Se...r+strip&sort=0
Old 09-10-2013, 10:22 AM
SW, Mike, Jimbo, thanks.
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
Old 09-10-2013, 10:39 AM
PonchoJohn PonchoJohn is offline
Silly question, but what's the bolt pattern on the wheels? If it's 120 mm vs 120.65 mm that could be the clunking you're hearing. Worth checking out.
Old 09-10-2013, 11:38 AM
Musclerodz's Avatar
They are 5x4.75 custom built by BOZE
Mike Redpath
facebook page
Old 09-10-2013, 12:47 PM
If lug nuts are tight, why would they clunk? I doubt Boze would screw up the bolt pattern.
The clunking is more like brake related, when pedal pressure applied or released,especially when turning around or backing up.Almost like pads are lose and flopping around.
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
