Old 10-03-2013, 10:56 AM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Originally Posted by parsonsj View Post
I talked to Tracy (at Anvil) about this and he said to put the car outside in the sun, and weight the hood over the support beams along the edge to pull it into place.
So the hood is outside with 250 lbs of stuff on it in a 90 degree Florida sun. He said if that doesn't work, he'll send me another hood.
that sure sounds like good customer service,good luck with hood,we need more pics of the car
Old 10-03-2013, 05:03 PM
Eeeeek. I hope he doesn't refuse the return since you did this.
If that doesn't help you can always cut, re contour the hood and re resin so it matches the fender contour. I've had to do that to a couple hoods.
Old 10-04-2013, 06:31 AM
parsonsj parsonsj is offline
I don't think Tracy would do that (refuse return after doing something he suggested). He was the one to blame the hood, rather than the fenders.
Anyway, after hours in the sun with 250 lbs (125 per side) flattening it, the hood profile remains unchanged. The experiment made no difference.
John Parsons
Old 10-04-2013, 02:48 PM
randy randy is offline
yup. same deal with my buddies hood. He ended up cutting it and making it fit. He left weight on it for weeks before that
Old 10-04-2013, 04:08 PM
Not much you can do once the resin sets. We had the same issue with hood we had too. Most likely what they made the mold off of. Then again I'm sure he has more than one mold.
