Old 11-01-2013, 10:42 AM
hifi875's Avatar
hifi875 hifi875 is offline
ive got a 5.3 in my 69. z06 243 heads milled .030 thinner headgaskets , custom compcams camshaft with holley terminator efi. not a torque monster but its ran 13.20 at 109 with terrible 2.0 60ft. with a stall or t56 it could run high 12s easy. they are good little motors that you can wind the pi$$ out of.
Old 11-02-2013, 10:44 AM
67Rally's Avatar
67Rally 67Rally is offline
How do you like that dual plane Edelbrock? I have the single plane Vic Jr with an accufab 4150 TB on it and it loves to wind up!
Old 11-02-2013, 11:12 AM
I did a 5.3 iron block motor with mildly ported LS6 heads, LS6 intake, headers, ported TB, and a small cam. Sounded good, idled nicely, and made 350/350 at the wheels through a tremec 5 speed. Torque curve was ridiculously flat and pulled to 6200. Car/engine had a lot spunk and was fun. Started as a complete pull out minus trans for like $600. Swapped/sold parts around with other platforms in order to get the correct oil pan, intake, and brackets etc. Modified the harness myself. Total outlay was around 2000 as I had the trans already.
In short, they are a good motor to choose capable of great power and enjoyment. A little more gets you a 6.0 though and a whole lot more power. Just have to decide how best to balance your goals and bank account.
Old 11-03-2013, 02:09 PM
67Rally's Avatar
I did a 5.3 iron block motor...Started as a complete pull out minus trans for like $600.
Unless the prices have come down on the 6.0's in the past few months, complete LQ4's were going for $1600-2000 and LQ9's were around $1800-2200 when I bought mine.
A 5.3 for $600 sounds like a good bargain. But if you want to make bigger power, then yes, a 6.0 is the way to go. It all comes down to budget.
Old 11-03-2013, 03:12 PM
hifi875's Avatar
It has a lot better throttle response. More bottom end torque too. It will still wind out also. Good intake for street use
Old 11-12-2013, 10:01 PM
jovozx12's Avatar
jovozx12 jovozx12 is offline
I agree on the 6.0L. I currently have a 5.3 in my 69 camaro and it runs great but I'm ready for more. If you do a 6.0 motor then you can run the LS3 heads which flow much better than a set of 243s.
