Old 01-04-2014, 03:01 PM
grif54 grif54 is offline
Default Aeromotive fuel tank
I was just wondering if anyone has used the new tanks from aeromotive for the fuel injected cars. I have a Chevelle that I am going to put an LS engine in. One thing I really like is that they look stock. From my understanding they use the Tanks INC tank and put their setup in it. Was wondering how well they do with cornering and the sump keeping full, I know that some tanks have issues with that. Thanks for any insight.
Old 01-04-2014, 04:21 PM
Blake Foster's Avatar
We just installed one in a 69 Camaro. they come powdercoated silver look great has the Stealth 340 pump in it if I remember -6 line hooks right up, you do need to use a pressure regulator up in the engine bay and a return line so that adds a bit to the job also an inline filter but it all is good stuff, just get all the Aeromotive parts and you should be golden
give us a call we are a Areomotive dealer and can get you everything you need
Blake Foster
www.speedtechperformance.com
Old 01-05-2014, 09:52 PM
Thanks, not sure when I will be getting around to ordering the fuel system because I want to get the body work done so the car can sit a whikle before paint. I was wondering if I could just use the corvette filter/regulator assembly, I have seen that used a lot before.
Old 01-07-2014, 08:29 AM
chr2002ca's Avatar
chr2002ca chr2002ca is offline
I installed one and have been very happy with it so far after about 1000 miles, although the sending unit is causing my Autometer gas gauge to be off. The gauge and sending unit both match in terms of 'ohms', so I'm not sure what the issue is. The gauge reads too high now, so when I get to a 'half tank' on the gauge I'm nearly empty in the tank. I just haven't had time to try to debug. Anyway, I do recommend the setup.
Chris Robinson
1969 Camaro SS/RS, 489 ZL-1 MPFI, T-56 Mag
Old 01-07-2014, 09:45 AM
OBeer-WAN-Kenobi's Avatar
It's because gas gauges and sending units are THE DEVIL!
Two of my vehicles are having one problem or another with the gas gauge. I just keep filling up whenever I'm in town.
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 01-07-2014, 11:56 AM
chr2002ca's Avatar
Yah, no kidding! The same gauge worked fine with my repop stainless tank and sending unit, but this new sending unit is sending a different signal. I'm going to check the ground wire to see if possibly I moved that when I was re-wiring everything. Like you, I just keep refilling often until I get it sorted out.
Chris Robinson
Old 01-07-2014, 12:44 PM
I've went through two gauges and as many sending units in my Willys and can't get that fricken thing to work. The worst is that sometimes it works and sometimes it doesn't with no rhyme nor reason. I even ran jumper wires to see if the wiring was faulty. I just finally gave up, at least until it's warmer again.
[/hijack]
'69 RS Camaro
Old 01-07-2014, 01:00 PM
I was wondering about the sending unit in them, I can never seem to get fuel guages to read correctly after you go to the aftermarket. It gets a little frustrating.
Old 01-07-2014, 01:07 PM
Just so you know I wasn't trying to ruin your thread...LOL, I do have a Tanks INC tank for my Camaro but I haven't installed it yet. It looks like a real quality unit though; especially for the price. I think I ordered it from MCB here on the forum and I bought it with a Walbro and the sending unit along with some new straps. I can't wait to see how it works, but that will be down the road a bit.
'69 RS Camaro
Old 01-07-2014, 04:28 PM
I didn't think you were trying to ruin the thread at all, any info about this stuff will just help me out or anyone who might come across it. I don't get around much on here but you can get all kinds of great info from the fine people on this site
