Old 03-01-2014, 04:57 PM
A-Guy's Avatar
A-Guy A-Guy is offline
Default New Gas tank/Fuel system
Hello all, can anyone point me in the right direction for a new fuel tank/system for my 72 Chevelle Malibu? I will be replacing the trunk floor and want to replace the tank at the same time. Eventually I plan on upgrading my engine to an LS platform and would like to go ahead and purchase a system that will be compatible. Any help will be greatly appreciated, thanks in advance!
Chris
Old 03-01-2014, 09:47 PM
CarlC CarlC is offline
Does the car have a carburetor now or EFI?
http:www.vaporworx.com
Old 03-02-2014, 11:43 AM
A-Guy's Avatar
It is a has a carb, 350
Old 03-02-2014, 12:43 PM
raustinss raustinss is online now
I have someone working on cad drawings for a tank for my 70...it will use a ctsv pump the rest is cad laser cut and welded. I'm a fabricator I can make two and ship you one or if you have access to a cnc laser or plasma..you can get someone to cut,form and, weld yours together
If your interested let me know Ryan Austin
Old 03-02-2014, 02:48 PM
Ketzer's Avatar
Ketzer Ketzer is offline
Carl can give you the best advice and is the first choice in tanks, pumps, etc. There is also one shown on TanksInc website that might be a lower cost alternative... several of the vendors on here are dealers for them.
http://www.tanksinc.com/index.cfm/pa...rod/prd388.htm
Jeff-
Old 10-23-2014, 09:24 AM
Notalent's Avatar
Notalent Notalent is offline
Tanks Inc or Ricks would be my choice, both top notch. Ricks is a more custom looking tank whereas Tanks Inc I believe is a modified OE style tank to suit your needs.
1971 Chevelle
ATK Engines 496 Stroker 675HP
TH400 / 9 Inch 3500 Stall
http://brandons71chevelle.weebly.com/
ATK HIGH PERFORMANCE ENGINES
WWW.HIGH-PERFORMANCE-ENGINES.COM
