Old 03-06-2014, 11:23 AM
glr0212 glr0212 is offline
Old 03-06-2014, 11:50 AM
jlwdvm jlwdvm is offline
Looks like they cut out a big section of the inner fender and bent the edge to make it rigid again? Probably rolled the outer fender lip too?
Old 03-06-2014, 07:06 PM
Supporting Vendor
You cannot use the Goodguys car as a reference. Every panel has been changed. Nothing is in the stock location.
Skunk Werks
Ridetech
www.ridetech.com
Old 03-07-2014, 05:15 AM
Yeh, I've heard that before, but there is nothing else out there for guys with a 69. I have looked at what Rodney has done with his...just looking for more reference to get ideas. Right now my main concern is the sway bar end link (where it bolts to the bar at the subframe). According to my wheel rite tool this is going to be an area of concern. But maybe my tool is wrong....it is a flimsy piece of plastic that is going back to Jegs after all! I'm starting to think I just need to order 18x9.5's with 6" back spacing to get my 275 R888's mounted and start pounding
Old 03-07-2014, 07:01 AM
If you are having a problem in that area what we do is weld in a piece of 3/16" steel plate which is drilled and tapped to accept the sway bar bushing brackets.
This will allow you to move the sway bar mounting back a 1/2" or more. Some frames you can back even farther. You can modify the spring opening flange.This will give you the room you need.
Old 03-07-2014, 07:25 AM
Thanks for the input. I'm not sure that would work for the design of the muscle bar since it is the bolt-on end link that is where the interference comes from. Maybe I'm looking into this too much or missing something.
Old 03-07-2014, 07:50 AM
Oh you went for the full monte. Yeah your fct. Those do get in the way. Everyone running them with good back space has that issue. Be much better if they were splined.
Old 03-07-2014, 08:11 AM
Interesting. So it is not uncommon to have tire interference with the sway bar? or is that a thing with only the r888?
Old 03-07-2014, 09:09 AM
I guess I could grind down the affected area of the sway bar arm (the front where it bolts the to bar) and then weld the ends onto the bars (if the bar ends are steel). It seems to me that designing the muscle bar so that the area where the ends bolt to the bar was located under the sub frame instead of past it into the wheel-tire area might allow for more tire clearance...but I am far from a engineer!
Old 03-07-2014, 09:43 AM
cwylie cwylie is offline
So I got the engine in this week and as you can see Im going to need a lot more camber. I currently have about a .25 inch of spacers on all 4 bolts. I dont think I could fit much more than a half inch without running out of stud. Generally how much spacer is needed to get to the 1.5 degrees of camber or so? Do you ever have to run longer studs? Anyone have a part number for some longer studs?
https://drive.google.com/file/d/0BwI...it?usp=sharing
