Old 04-05-2014, 11:11 PM
clinkster clinkster is offline
OK guys so I finally got some pics of my seat issue. I finally decided to modify the seat brackets to sit flat on floor boards. I will use the two outer existing holes with longer bolts and follow up with thick washers underneath with an additional nylon nut. On the inside I will drill hole through floorboards and follow with same thick washer and nylon lock nuts as well. I will use all grade 8 hardware as well. if you guys see anything further needed please let me know. thanks
Old 05-01-2014, 08:28 PM
RECOVERY ROOM's Avatar
Supporting Vendor
RecoveryRoomInteriors.com
your on the right path, Make sure your welds are GOOD !!
TRACY WEAVER
www.recoveryroominteriors.com
