Old 05-19-2014, 08:22 PM
jlwdvm jlwdvm is offline
Default Ride Tech 4-link install in a 69 Firebird?
I'm in the process of installing my Ride Tech 4-link with coil-overs and Strange 9"in my 69 Firebird project. I have the lower bars mounted. It took a little tugging to the passenger side to get that bar mounted. I am using my jig that I set to 9 1/4" to get the upper bar tabs mounted. I have a plumb line taped to the side of the quarter and hanging through the center of the axle line to get my side-to-side measurements. It is showing that the rear is biased 1/2" to the drivers side at the moment. I can get the rear to move to the passenger side, but it wants to return to the drivers side when I let go. Just wondering if this is normal until the upper bars and shocks are installed? Will this cause the rear suspension to bind? As it sits at the moment, the rear is 8.5" below the frame per the instructions. Any thoughts?
Old 05-20-2014, 12:35 AM
I had a few of these...now I just cut the perches off and run the Ridetech lower bracket. Center the axle. No headaches.
http://www.ridetech.com/store/weld-o...ch-4-link.html
Old 05-20-2014, 06:27 AM
dhutton dhutton is offline
I am pretty sure I read a post that describes how you adjust the upper bars to make a small adjustment to the centering of the rear. You only need to shift it over a 1/4 inch if I followed you right.
Edit: Here is the thread:
https://lateral-g.net/forums/showthread.php4?t=42946
Old 05-20-2014, 07:46 AM
Thanks for the lead. I don't want to have to remove the spring perches. Currently I am trying to center the rear axle so i can weld on the upper tabs. Looks like the upper tabs then allow yo to fine tune axle centering under the car. As far as I know, the rear frame rails are stock with no damage, but both quarters are aftermarket installed by the previous owner. I suppose there could be some variation there since I am using them as a reference.
