Old 05-27-2014, 09:18 AM
wiedemab's Avatar
wiedemab wiedemab is offline
Originally Posted by Ravenworks View Post
Is this bearing currently available over the counter or is this a special piece you are having made?
I'll let Mark confirm, but I believe he stated that if you aren't going to run the ABS setup like he has, you can simply use the ZR1 part directly from GM.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 05-27-2014, 09:22 AM
Ron in SoCal's Avatar
[QUOTE=wiedemab;552750]
Brandon I think you are correct. What Mark mentioned is that he special ordered a passive sensor hub to integrate into the GM ABS system he's using. The standard ZR1 hub, which is the big daddy of SKF's line up for GM, can be had at the dealer. It's an awesome peice.
Ron in SoCal
69 Camaro in progress
Old 05-30-2014, 10:19 PM
ADiCarlo ADiCarlo is offline
Not to jump subject but could we get some pictures of the cage - it looks incredibly well tucked.
Did you use DOM? And the kick downs in the trunk are they re-enforced in anyway - I see one going to the DSE crossmember but the other is attached to what I think is welded sheet metal.
Also I think you need to convince DSE to add the cooling ducts as a subframe option.
Old 06-04-2014, 09:51 PM
Keithq68 Keithq68 is offline
Default ABS module.
I was wondering what the difference is between the two different ABS modules.
Does the Delphi have any benefits that made you choose it over the Bosch setup?
I'm assuming there has to be some kind of benefit since you went through the trouble of having custom hubs made with the older style wheel speed sensor.
Thanks for any info you can offer.
Keith Quinn.
Old 06-05-2014, 11:30 PM
89 RS's Avatar
89 RS 89 RS is offline
Another awesome build, awesome shop, and that is a really cool car gathering...that's my kind of party!
Corey
1989 Camaro RS
Old 06-08-2014, 09:12 AM
Stielow's Avatar
Stielow Stielow is offline
Lightbulb
Keith Quinn.
The Bosch production system required communication to a body control module over CAN. Adding the BCM in is a bit tricky. The Delphi system can run more stand alone and had been used stand alone in racing. Newer system are more linked together over CAN. As an example the brake switch and the warning lights are on the CAN bus in a C6 Corvette. So to go from a discreit input (on / off) to a CAN input to the ABS module requires a converter box.
All the newer ABS system have stability, traction, ice and snow modes incorporated. Which means it needs to communicate to the whole car via CAN. Trying to make a OE system stand alone is hard.
Bosch offers a racing stand alone system that is laptop programmable that is great but spendy. That system is very flexible.
Mark
Old 06-08-2014, 10:21 AM
I wish you'd volunteer to look at my Lotus 2 Eleven ABS and figure out how to make it NOT go into ICE mode when going backwards (a known bug). :>)
Old 06-08-2014, 01:29 PM
Che70velle's Avatar
Greg, my degree in theology and biblical studies doesn't quite compare to Mark's engineering degrees, but I think I can help you on this one.
When you start the Lotus, and get ready to roll out on the track, take a careful look at your gear selector. You will see an "R" which is for REVERSE, not RACE.
Sorry man, couldn't resist that one...
Mark, sorry for misdirecting the thread momentarily...
Thanks Dad!!
Old 06-08-2014, 02:05 PM
How can he practice his Rockfords without full reverse?
Old 06-08-2014, 09:14 PM
Default Abs.
Thanks for the reply Mark.
I have been following your builds since the Mule, I've loved every one of them.
The latest car is over the top, can't wait to see it finished.
Not trying to hijack your thread but I have a few more questions now.
That's good info about the ABS, I didn't realize that the new Bosch unit required the BCM.
I have a 2010 C6 engine wiring harness for my car. I had originally bought a Delphi Z06 ABS module. The harness i have includes the connector for the Bosch unit so I bought a Bosch module. I was going to run the BCM as well to get the control for the ABS unit.
I'm running 08 hubs and speed sensors so i guess they are compatible only with the Delphi module.
I'd like to run the Delphi unit so that I don't have to buy new hubs. I haven't been able to find the connector for the Delphi unit. The dealer tells me i have to buy an entire harness.
Do you know of a supplier who sells the connector or have a GM part number?
Love the 2 Elevens Greg. My brother has one that he just bought this year. He's loving it but is having trouble with the second gear synchro.
He's looking into either a dog box or a sequential now.
Thanks.
Keith Quinn.
