Old 06-02-2014, 10:11 AM
cjfirstgen's Avatar
cjfirstgen cjfirstgen is offline
Stripped and epoxy sealed. Originally a vinyl top car we found the typical rust from the window channel location...typical. Car was media blasted and body filler was used. It was holding fine surprisingly but we will cut this area out and replace to save the OE quarters. The rear deck fill panel was replaced with a NOS stamping.
Project "Mercury Rising" '69 Camaro : https://lateral-g.net/forums/showthread.php4?t=41460
Old 06-04-2014, 08:06 PM
cjfirstgen's Avatar
Ben did a great job in capturing my vision and plans. Really motivated to keep pushing to the finish line.
Old 06-04-2014, 08:17 PM
Ya gotta love the looks of that!!!
Old 06-04-2014, 08:29 PM
fleetus macmullitz's Avatar
Excellent...that's gotta really help.
Old 06-06-2014, 08:45 PM
Awesome rendering!
Old 06-06-2014, 08:53 PM
Love it and I typically don't like red. Maybe I'm coming around to the color with all these good looking cars being painted red. Hmmmm. Regardless, good luck with the build
Old 06-06-2014, 09:46 PM
cjfirstgen's Avatar
Awesome rendering!
Thanks for all the comments!!! Very much respect the opinions around here so it means a lot.
My first red car ever and I certainly had the chance to change the color but something about Guards Red with the black hockey stripe just grabbed me and won't let go!
Old 10-05-2014, 06:27 PM
cjfirstgen's Avatar
I changed my project name....sounds much better and certainly appropriate IMHO. Never really like "Flux"..."Twice Baked" seems more fitting since this is the second major rebuild of this car in 7 years.
Moderators...can you change the name of the thread as well?? Hopefully that is allowed. Thanks in advance.
Some updates:
Change of plans.....New AMD quarters, outer wheels wells and door shells. Overall was very clean considering the born with quarters were still on the car but ultimately needed replaced to match the caliber of the build. Besides I just could not stand not getting to the inner quarter and taking care of the unknown (ie. rust). Pretty close to having all the sheet metal fitted with proper 3/16" gaps.
Old 10-05-2014, 06:30 PM
cjfirstgen's Avatar
Meanwhile doing some tinkering with the subframe...Willwood 6P brakes, bump steer tie rod ends, etc.
Old 10-05-2014, 06:36 PM
cjfirstgen's Avatar
Took the motor back out of the subframe.....decided to have it gone through plus bumping compression with new pistons, ARP hardware throughout, AFR CNC heads, custom cam, etc....should be north of 800 on pump gas. Will post the dyno run soon.
