Old 06-11-2014, 06:41 PM
redsand redsand is offline
Default Really need some help
Been getting different answers and need to confirm with the team here that have run the following to 100 percent confirm
69 camaro
Dse mini tub
Ride tech 4 link
Has anyone successfully run a 335 tire with an 18x12 wheel without rubbing.
Some searches I have found where Bret said yes, they have run a 335 and had some answers saying the g r/s givaway car had them but there was some rubbing
I just need a 100 percent confirmation if anyone is running the setup with a mosier 12 bolt stock length
Also what backspacing did you run in the rear??
Any help would be extremely appreciated
Old 06-11-2014, 07:54 PM
Someone else can weigh in, but its all in the backspacing. 69 Camaro and minitubs fits a 12 wide with 335s no problem, you just have to nail the backspace for your diff width. We do it lots but with Speedtech rear torque arm.
As long as your rear suspension is centered and you measure twice for backspace, you'll be fine. You might have to trim back or fold up the edge of the quarter lip depending on your chosen ride height but thats it. Heck we can even pull our 19x12s on one of our camaro installs without dropping the coilovers and the diff down, just because of its ride height.
Tyler
HPI Customs
Manitoba, Canada
www.hpicustoms.com
Old 06-12-2014, 04:32 AM
I have plenty of wheel tub.... My problem is that the 335 when mounted in the wheel well seems to hitting the bottom bar of the 4 link or is very very close and being told might rub
Old 06-12-2014, 05:44 AM
dhutton dhutton is online now
Do you have the offset lower bars?
Old 06-12-2014, 06:21 AM
LS7 Z/28 LS7 Z/28 is offline
If it's in the way, move it. I would add a 1/4 or 1/2" wheel spacer to each side and clearance the quarter panel lip of the wheel opening if you are concerned about it. I'm assuming you don't want to modify the suspension. I think that will be the easiest route to achieve what you're after.
Old 06-12-2014, 07:38 AM
Musclerodz's Avatar
you need the offset lower bars if you don't have them. otherwise it should clear fine.
Mike Redpath
Musclerodz & Customz
facebook page
Old 06-12-2014, 02:47 PM
Default off set bars
I have the offset bars but what I am seeing is that they are offset but when going towards the housing they move back out toward the tire which feels like it is defeating the purpose of the offset....
Shouldnt they be perfectly Parallel and not have an angle from the front leaf pocket to the rear end housing?
Old 06-12-2014, 02:53 PM
Ron in SoCal's Avatar
^ Mystery solved?
Ron in SoCal
69 Camaro in progress
Old 06-12-2014, 06:26 PM
Well not yet
The only thing I can think of is that the brackets are not on the axel correctly
Old 06-13-2014, 06:04 AM
Originally Posted by redsand View Post
Well not yet
That would be my suspicion. Who installed them?
