Old 07-01-2014, 10:54 PM
FETorino's Avatar
FETorino FETorino is offline
For the best rear articulation you don't want a triangulated 4 link. For some how to advice start with post 11.
https://lateral-g.net/forums/show...t=42568&page=2
Rob in SoCal
Old 07-02-2014, 06:22 AM
jarhead's Avatar
jarhead jarhead is offline
Thanks, I had never seen this...
joe
Semper Fi
My 68 Torino
Old 07-02-2014, 11:50 AM
dhutton dhutton is offline
Somewhere out there a magazine (PHR?) did a performance comparison between the AME triangulated four bar and three link suspensions on the same car. Difference in performance was very small if I recall.
Edit: Here it is:
http://www.superchevy.com/how-to/cha...pension-tests/
Video: https://www.youtube.com/watch?v=aO2yva2JvAY
Old 07-02-2014, 04:47 PM
jarhead's Avatar
Edit: Here it is:
Thanks Don
What you need to do is call AME, tell them what it is you want to do and let them guide you. They will have their Engineers look at what needs to be done to do it right and advise you on how to achieve your goal. Customer service at AME is very impressive. Ask for Scott. I've dealt with him before and the guy is awesome.
Talked to Scott today, thanks for pointing me that direction, he had allot of great advice!
By the way ---- That's exactly how I'd go about updating the suspension. You can buy all of these parts from Morrison or DSE and do without the chassis portion. Morrison folks are super helpful --- and it's really just a whole bunch of measuring - tacking in the mounts - landing the arms - triple checking and squaring --- before you weld 'em final.
I did my brother in laws Camaro with about half a dozen plumb bobs --- a couple squares -- some straight 1 by tubing - pulled about a zillion measurements off before I ever started and wrote them all down... and checked for square and went to cutting....
I added a crossmember for Rudy since his is pro street and he's running 18" wide tires... so I couldn't land the stuff anywhere near his existing frame rails (if you call the tin crap in a '69 Camaro a frame rail). Originally on his job we were leaving everything else alone -- so I even flipped the crossmember upside down and used it as a driveline loop... rather than cut up into his floor.... of course then we ended up gutting the car and doing all new upholstery --- so I could have welded it in correctly and attached his whole floor to it but OH WELL.
I think I am going to buy the parts from AME and do the install the way you mentioned.
Thanks for steering me back in the right direction again. Scott with AME said the triangulated would be a tough install for a first timer.
And after I read all the Ron Sutton stuff the parallel sounds like the way to go. I need to finish all my other projects on the GT first, then I will tackle this. I do think I have decided on the AME package after talking to Scott, I will just do it with their parts and not the clip after I understand it more.
joe
Semper Fi
My 68 Torino
Old 07-02-2014, 08:38 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Glad to hear you talked to Scott and that it was beneficial.
Curtis
Old 07-03-2014, 04:44 AM
Thanks Don
Isn't a parallel setup mostly for drag racing with the exception of the Quadralink that has the swivel links to allow it to articulate? For best articulation I thought it was a three link followed by a triangulated four link, except as noted for the quadralink.
Old 07-03-2014, 08:53 AM
jarhead's Avatar
I was going by this from that Ron Sutton link…
For the best adjustable rear suspension for road racing, track car, or AutoX car, is the adjustable 3-link, as it has the best articulation. The adjustable parallel 4-link will work well as long as the car doesn’t require a high degree of roll angle for the suspension to work.
joe
Semper Fi
My 68 Torino
Old 07-03-2014, 09:25 AM
Art Morrisons tri-five chassis has been proven to pull over a G... using the triangulated 4 bar... And this is nothing but a simple "replacement" chassis with somewhat improved suspension geometry. So unless you're going to be a competitive road racer, I don't see why this simple suspension wouldn't suit you just fine.
Old 07-03-2014, 11:36 AM
I am confusing a four link with a four bar. Sorry about that. I should know better than to post by now...
From the AME website:
4-Bar vs. 4-Link: A Tech Overview...
In a nutshell, a 4-link setup is best
suited to Drag Race or Pro Street type
vehicles where high horsepower engines
and large tires are being used. The 4-link
can be adjusted easily to compensate for
track conditions and control the amount of
“hit” the tire takes on the launch. And due
to the high kick-up of the frame rails,
modifications to the trunk and rear floor
are required—often times the rear seat
must be removed.
The 4-bar has longer, parallel bars and
a lower frame kick-up. It is ideally suited
to street and air spring suspension setups,
provides more latitude in setting ride
height and its polyurethane-bushed rod
ends make for a smoother, quieter ride. In
most installations the rear seat can be
retained, with little or no modifications the
seat itself. It’s neat for the street!
Old 07-03-2014, 02:25 PM
Don't confuse 4 BAR or PARALLEL 4 BAR with Triangulated 4 Bar -- they are COMPLETELY DIFFERENT configurations other than they use 4 bars...
