Old 08-05-2014, 09:17 PM
SSE0417's Avatar
SSE0417 SSE0417 is offline
Default Time For The Wiring
I'm down to the wiring and mounting the computer. Does anybody have any good ideas where to mount the computer? And possibly come though the fire wall at? I kinda have a idea but but was just looking for more ideas maybe from someone that has done it already.
Old 08-05-2014, 09:29 PM
I usually mount it where the battery was. Easy to access if you have to and it stays cool.
On our current build we are running it under the dash. Above where the parking brake lever was. Pass through is right behind the intake manifold using a split seal. 3" hole but 1" wire pass hole.
Old 08-06-2014, 05:29 PM
mikeextrafast's Avatar
mikeextrafast mikeextrafast is offline
It depends on the harness you have. I drilled a 2 1/2" hole behind the passenger side head and mounted the ECU above the glove box
Old 08-07-2014, 07:21 AM
130fe 130fe is offline
Which PCM are you using?
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 08-07-2014, 09:04 AM
youthpastor's Avatar
first gen is usually behind glove box for us. Just spent Monday mounting a GM connect and cruise- about the worst to find locations for. 3 components - harness wrap cut off and rewrap the the harness so it works. The fuse box is accessible right under glove box -
[SIGPIC][/SIGPIC]
CHRIS HOLSTROM CONCEPTS
http://chrisholstromconcepts.com/
Old 08-07-2014, 06:49 PM
I went with a harness and computer from Spankys Rod Shop only 3 wire hook up very small fuse panel,and small ECU ...Very nice stuff the whole harness is shrink wraped ....
Old 08-12-2014, 02:55 PM
ironworks's Avatar
We sell a few bracket to make this process much easier.
http://www.ironworksspeedandkustom.c...e=cat/cat2.htm
