Go Back   Lateral-g Forums > Vendor Specific Technical Discussions and Support > Roadster Shop Chassis and Components
Old 12-22-2011, 06:06 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Awesome work. I'm anxious to see this one done. I have a soft spot for those Chevelles.
Old 12-29-2011, 09:36 AM
Roadster Shop's Avatar
Supporting Vendor
RoadsterShop.com
The rear bumper is underway. Chris sketched up some ideas that will really set off the rear of this car.
Not too much of the original metal left here!
The bumper has been narrowed and tucked tight to the body. Now working on fabbing a new sheet metal center section for the bumper.
www.roadstershop.com
Old 12-29-2011, 09:58 AM
Kendall Burleson Kendall Burleson is offline
killer back end that will give it another look, Are you changing the rocker to flow with the rear?I have been keeping up with the build more pic.
Old 12-29-2011, 11:38 AM
mild2wild mild2wild is offline
More awesome work by the RS team!
Old 12-29-2011, 06:49 PM
norm86 norm86 is offline
quick question when you guy are doing a car that need all new sheetmetal do you all use the weatherstripping to check correct door to 1/4 and trunk to 1/4 fit?
norm86
Old 12-30-2011, 08:36 AM
Supporting Vendor
RoadsterShop.com
Norm, we will generally either buy 2 sets of weatherstrip for the car (one for mock up and the other for final assembly use) or we will figure out the thickness of what the weatherstrip is and then tape rubber or shims in place to act as the weatherstrip.
Old 01-05-2012, 01:11 PM
Supporting Vendor
RoadsterShop.com
Some further progress on the rear bumper. It is just about completed at this point. We need to go back and fine tune the gaps and final mount the bumper and lower valance. Then begin on the center exhaust tip.
Splitters added to the recessed area
Old 01-05-2012, 01:53 PM
skatinjay27's Avatar
2 things:
that rear end treatment is awesome.
sweet! another shot of the secret car!
AJ
Old 01-05-2012, 01:54 PM
coolwelder62's Avatar
Not Bad.
Old 01-05-2012, 06:08 PM
tones2SS's Avatar
Wow. Looks great guys!
