Old 10-27-2014, 09:48 PM
68LS1's Avatar
68LS1 68LS1 is offline
Default Looking for Timing Cover to suit Double Row Timing Chain
Hope someone can help on leads for a timing cover that will clear a double row timing chain. My engine is an LS3. The current stock cover has seen better days
Comp Cams claim that theirs does but a review on Summit, says they had to grind it also.
thanks
Roger
68 RS Camaro Convertible LS1 6 speed
72 C10 SWB Stepside, old skool 350 4L60e
71 K5 Blazer 350sbc T350
Old 10-30-2014, 08:09 PM
I saw a video on you tube that they only touch in a few spots and you can check them and grind a few small spots to make them work.
Hamburger's used to make a 2 piece front cover not sure if they still do or how much $$.
Old 10-30-2014, 08:22 PM
Ron in SoCal's Avatar
Jesel makes one
(j/k)
Ron in SoCal
69 Camaro in progress
Old 10-31-2014, 12:42 AM
68LS1's Avatar
I'm aware I can grind the factory cover, but mines toast. So looking for some more bling factor also.
Hamburger do still make them, around $400. This is looking like the most likely.
I thought there would have been someone who used a double row. Further reading seems to say timing chain is not a problem of LS engines, but this engine was already fitted with the double.
thanks for your input.
Roger
Old 10-31-2014, 12:45 AM
68LS1's Avatar
Jesel makes one
(j/k)
This one's gone over my head
Roger
Old 10-31-2014, 08:12 AM
http://www.jesel.com/valvetrain/index.php/belt-drives
It's an open container violation.
Ron in SoCal
