Old 01-04-2015, 09:32 AM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Default Moser or Strange Housing Ends T-Bolts?
Hi Guys
I have ford 9 inch rear end, and I stripped one of the housing end T bolts while torquing.
I was searching for T Bolts and found the Moser ones which run for $15 a set and T bolts from Strange, which run for $30 (twice as much).
Just wondering which brand has got better quality fasteners, Moser or Strange?
72 Camaro RS:SOLD
68 Camaro:
Old 01-04-2015, 10:19 AM
When they come in the assembly kit they come in identical packaging and they even look to be the same part too. Go for price and lube it up.
Old 01-04-2015, 11:37 AM
MeanMike MeanMike is offline
The moser are fine quality. Make sure you get the right size. They come in 3/8 and 1/2, measure your housing ends to be sure.
Old 01-04-2015, 01:29 PM
randy randy is offline
I didn't use my T bolts with my kit. What is the nut size? Ill send them to you
Old 01-04-2015, 01:34 PM
72Z/28's Avatar
I have seen the sample photos of both brands, the lock washers and nuts in Moser look a bit different than the ones from Strange. Maybe the actual items look the same as you said.
So you recommend to go with Moser?
72 Camaro RS:SOLD
68 Camaro:
Old 01-04-2015, 01:36 PM
72Z/28's Avatar
It is 3/8 " size bolt.
72 Camaro RS:SOLD
68 Camaro:
