Old 02-21-2015, 03:58 PM
Sonar Chief's Avatar
Cool
Nice ... I was wondering how they might work out, looks like they are just what you need for the swap.
Thanks for sharing .... might be a rev. 2 for my 12 bolt!
Old 02-23-2015, 09:04 AM
syborg tt's Avatar
Wow that is a great looking kit for the 9" almost makes me want to swap to a 9.
marty-mj
Old 02-23-2015, 09:24 AM
paulk68 paulk68 is offline
"The directions don't include a single measurement or diagram to help you locate the brackets. They make it seem like they fall into place but that is not the case especially when using a 9".
After calling and getting as much info as possible I starting installing the brackets. I needed to modify the upper brackets to fit on the 9" housing but finally got everything where I thought they should be and welded the brackets on."
The products are great but I have struggled with the directions as well and called several times to clarify. I was hoping they were a little more detailed.
Old 02-23-2015, 02:57 PM
bsharpe bsharpe is offline
It is great setup. I lucked out and the timing worked perfectly for this build.
You can use the flanges with the 12bolt but you would have to tear it apart to put it in a jig.
You need to build another car. I remember seeing you have one of Scotts subframes sitting around.
I just hope more builds start using ABS. I need more info so its easier when I try to add it.
It is great that they have people on the phones answering questions but i would prefer all the info added to the instructions. I work on my stuff at night and dont like to make calls.
Old 02-23-2015, 03:16 PM
I finished installing the 4 link and 9". I decided to keep my frame rails since they are in great shape and thicker replacements were offer $500.
I tried to strengthen the frame and 4 link bracket to prevent cracking. It looks like the other cars frame cracked in front of the 4 link cradle/bracket. This is where the frames are thinnest from being bent.
I took a piece of 1/8 angle iron to strengthen this area. I welded it to the ridetech bracket hoping it would help distribute the load. I also welded the ridetech bracket in a few spots to help secure it.
Old 03-21-2015, 12:49 PM
Now that the rear suspension and axle have been installed i can finish up the trans and driveshaft tunnel. The 6l90 is huge and requires the trans tunnel to be widened and raised. The yoke is also very high compared to other trans and required the cross brace to be replaced and the driveshaft tunnel raised.
With that done i am going to work on test fitting the interior. I am stealing the seats from the chevelle. I like them a lot and they will work better in the trans am.
Old 03-26-2015, 06:46 AM
The interior has been installed. I mounted the seats as low aspossible. Im only 5'9" and have 4" of clearance above my head which should be plenty of room.
Old 03-26-2015, 10:29 AM
Justin@EntropyRad Justin@EntropyRad is offline
Default Wicked
Love this thing, especially the recaros
Old 03-26-2015, 11:47 AM
Nice work. Tell me more about them there Recaros , would ya. Thanks
Old 03-27-2015, 09:51 PM
I got the seats from a Saturn ion redline. They should be tha same as the chevy cobalt ss seats. I really like them and they fit me well. They are taller than regular recaros and are not a good fit for most muscle cars.
