Old 02-23-2015, 09:53 AM
68400BIRD 68400BIRD is offline
Car is looking great as usual Tu. Looking forward to seeing some tires on the new rims.
Old 02-23-2015, 10:10 AM
GMTILT's Avatar
GMTILT GMTILT is offline
Smile
looking good, I always have a soft spot for a 67-68 firebird
http://gmtilt.com/
Old 02-23-2015, 11:01 AM
Errnie-ZL1 Errnie-ZL1 is offline
Default looks great
Hello my friend looks great allot of time and elbow grease went into your build i see. This is what i like to see a fellow car guy do things himself great job love the bird!!!!
Old 02-23-2015, 11:21 AM
rickpaw rickpaw is offline
People that have NOT ordered or worked with him....have no idea what they're missing out on!!
Greg, you're 100% correct. Ron actually following up after the sale to make sure everything was correct, unlike typical salesmen that disappear after the sale.
Thanks for the comments guys.
Tu Ho
Old 03-09-2015, 08:34 AM
Blackened Blackened is offline
Also installed 1" lowering blocks on the rear. Do I need to add something to take up the space between the spring perch and shock plate?
[/QUOTE]
Yes, you are missing the leaf spring pad:
http://m.summitracing.com/parts/oer-rl8e
Why are you changing the wheels? And nice work on rescuing the Firebird from slowly rusting away!
Old 03-09-2015, 09:23 AM
NvrDun71 NvrDun71 is offline
Tu slightly off topic but how do you like the ridetech HQ's? Also what leafs are you running out back?
71' Nova - LY6, T56
Old 03-09-2015, 09:30 AM
I was referring to the spots where the U-bolts are. I have leaf spring pads between the springs and axle perches. The original mono leaf had a pad between it and axle perch, but not on the shock plate.
The Budnik wheels were nice, but it has the valve stems behind the spokes. I had to use flush mount stem to clear the calipers, and them flush mount stems are quite a pain. There are times when I checked the tire pressure and found out the stems are behind the calipers.
Tu Ho
Old 03-09-2015, 05:52 PM
n77nxc's Avatar
n77nxc n77nxc is offline
Post up pics of the car with the new rims. They look awesome!
1967 Camaro - Project "Resale Red" - Sold to 175RGR
Old 03-09-2015, 08:18 PM
I like them a lot. Had KYB shocks before and the ride was quite harsh. The Ridetech shocks made a huge improvement. The springs are Hotchkis 1.5" drop springs.
Thanks Jason. As soon as we have decent weather I'll get some decent shots. As you know we have been having crappy weather.
Tu
Tu Ho
Old 03-16-2015, 06:32 AM
With Jason's help (n77nxc), I found a place in SW Houston that has a touchless tire machine. Brought the new Formula 43 wheels down to them, and had the tires mounted. Last weekend, the weather was nice enough so I rolled the car out of the garage, and snapped a couple of pictures with the new wheels.
Since I signed up for USCA event in Texas, a helmet was needed. My 6 year old daughter couldn't wait to try it on, right out of the box. G-force carbon helmet.
Now I just have to get the car aligned, nut/bolt check then I should be ready to go.
Tu Ho
