Old 09-11-2006, 08:08 AM
nitrorocket's Avatar
Default What is overall O.D. of front c6 & Z06 front brakes??
I need to know what the measurements either from center or overall o.d. from one side of the rotor to the outside of the caliper. I am trying to figure out what will fit inside my front wheel.
I would like a dimension off the new C6 ZO6 and a standard c5 and z06 setup. Anyone feel like jacking up there car, pulling a wheel, measuring, putting the wheel back on and letting the car back down just to get a measurment for me??
I am sure many other people would like this info also!!
Twin Turbo LS1 '71 Chevelle
1000 hp 93 octane street car
6 speed
Old 09-11-2006, 08:26 AM
fatlife's Avatar
fatlife fatlife is offline
Banned
z06 for sure won't work with your wheels, C5 probably won't work without a spacer. I know my centerlines wouldn't work with the C5's I had, but I think they worked with Dennis's centerlines. Sorry don't have any measurements off hand
Old 09-11-2006, 08:35 AM
That is why I am looking for solid #'s.
6 speed
Old 09-11-2006, 08:53 AM
fatlife's Avatar
Banned
I believe the prob with the C5 I had was the distance from the face of the caliper towards the back of the face of the wheel. I might be able to get you some C5 dimensions today
Old 09-11-2006, 09:08 AM
Cool!
If I remember right, I have 1" from the flange face to the web of the wheel for caliper clearance. I will have to measure tonight to verify, It was a long time since I measured that!
6 speed
Old 09-11-2006, 11:03 AM
Beach Cruiser's Avatar
Beach Cruiser Beach Cruiser is offline
I have the C5 Z06 Stuff on the bench, can put it together and take some measurements this eve. Planning on mounting them on a C4 spindle and using Z06 wheels.
Old 09-27-2006, 07:09 PM
FASTRC5 FASTRC5 is offline
Default Better late than never
For C6 z06
wheel CL to outside of caliper is 200.5mm
hub mounting face to most outboard part of caliper is 50.18mm
hub mounting face to most board part of caliper is 101.81mm
hub mounting face to mounting face of caliper is 63.42mm
rotor radius is 177.5
Old 10-02-2006, 07:35 PM
Wow, so that rotor and caliper setup will fit in my wheel! I have to check the mounting surface to caliper for web clearance though.
6 speed
Old 10-03-2006, 05:22 PM
Leadfoot1's Avatar
Leadfoot1 Leadfoot1 is offline
Default Like he said....
http://www.kore3.com/tech.php#fitment_templates
I'm looking at this too.
Killer set up!
Lead.
LEADFOOT1
New for summer '13. My latest find!!
48k miles, 100% original, 1969 Camaro coupe. Untouched, never apart and squeaky clean!!! 327/th350, A/C car. Gold on black w/vinyl top. Only add ons; Fast ratio box and SS396 wheels.
FINALLY!!! A car without rust repairs ever!!! None before, none coming!!! Cant come to modifying it tough....
...So, '67 Camaro project with my laying around stuff out of my black 'vert. 468 BB and YSI blower, braked th400, 12 bolt/spool, 35 splines etc. Complete Calvert suspension front and rear. 30x13.5 ET Streets, caged, lightened, slammed and running low 9's "Street car"
