Old 04-29-2015, 06:46 PM
MaxHarvard's Avatar
Originally Posted by jlwdvm View Post
Does your Stack dash plug directly into the OBD port for the motor? Any reason you choose that dash over the other digital dashes on the market?
Nope. I wish it did but it doesn't.
Honestly, I got it because I've used it before and its awesome and #2 it fits perfectly in the dash.
Old 05-07-2015, 08:34 PM
MaxHarvard's Avatar
Awww it thinks it's people!
Old 06-01-2015, 02:04 PM
MaxHarvard's Avatar
Mild updates... Little tasks are under way, worked solidly for 6-7 hours the other night and very little physically changed. Ah well, that's how the details go.
Test fit the front clip.
Got the rear tail lights to work with functional reverse lights.
Dash test fit and mounted.
Mounted pass. side mirror.
Fabbed up an inner door panel out of aluminum and plastered with vinyl faux carbon fiber wrap... Probably going to change this eventually when the interior is completed but for now it works.
Underside of the door handle.
Backup camera testing.
Shark fin for mounting camera.
Wiper motor installed.
Gratuitous rear-end shot for no other reason than just because.
Crude alignment.
Calibrating the fuel sending unit with my lovely assistant whom does not need calibrating.
Aerocatch studs. Made a series of aluminum plates top and bottom to support the studs.
Pic of 90* air intake. Again, crude but effective.
Old 06-01-2015, 03:01 PM
syborg tt's Avatar
Wow is all I can say.
Are you going to be street driving this beast and if so how hard is it to get titled and insured ?
I talked to my agent about a Brookville Roadster pick up and they told me that I wouldn't be able to insure it through them and would have to go to a specialty insurance company and suggested I take a 2million dollar umbrella policy as added protection.
marty-mj
Old 06-02-2015, 09:16 AM
Evan Iroc-Z Evan Iroc-Z is offline
What an absolutely beautiful build!
'89 IROC-Z Turbo 3.8 5SPD
LS1 Brakes|Wilwood Prop Valve|LS1 Master Cylinder|Aluminum Driveshaft|LS1 3.42 Rearend|Adj PHB|Adj LCA|LCARB|Koni Struts|Koni Shocks|Adj Caster/Camber Plates|STB|10 Spoke SS Wheels|PHB Relo Kit|Adj TA|SFC|ARAP Based Prom|B&M Short Shifter|Underdrive Pullies|SMOG!|AIR!|Rag Joint!|Magnaflow|Ported Plenum|Misc Stuff
Old 06-02-2015, 12:08 PM
MaxHarvard's Avatar
Yep, it is street driven. I got license plates and will have to get it inspected before I get the full title. So we'll see how that goes.
As far as insurance, I went through my regular agent and did an agreed value policy that would cover the cost of parts, but no labor. $500/ded and a full year payment. Cheaper than my daily!!
Thanks, it's getting there!
Old 06-02-2015, 04:55 PM
Scott Haggai's Avatar
Scott Haggai Scott Haggai is offline
Wow! That looks sweet!
Old 06-03-2015, 11:24 AM
MaxHarvard's Avatar
(insert maniacal laughter)
Old 06-03-2015, 12:31 PM
LS7 Z/28 LS7 Z/28 is offline
Eric, will you be at the Street Machine Summer Nationals show in a few weeks. I definitely want to check the car out in person.
Old 06-03-2015, 02:23 PM
MaxHarvard's Avatar
I sure will be!
Going to try and get it into the competition
