Old 06-10-2015, 09:48 AM
DKz Garage's Avatar
DKz Garage DKz Garage is offline
Default Air intake
Any ideas on what is the best air intake set-up for a 69 Camaro with LS and a 92MM Fast Tb. I need to mount it towards the drivers side and have a spot for the MAF sensor. Aluminum would be best ......
Old 06-10-2015, 10:42 PM
no go nova's Avatar
no go nova no go nova is offline
Aluminum or steel would work but would heat soak more. Some type of plastic or rubber would or should hold a cooler air temp as the engine and enginebay warms up.
Old 06-11-2015, 10:19 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
I used the Spectra on my last car and also using it on my new car.
They changed now and the Maf plate comes loose and you weld it where you want it.
Old 06-11-2015, 10:21 AM
Vega$69's Avatar
Used Airaid on another 69 that also worked well if you don't want aluminum
Old 06-19-2015, 04:25 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
Wouldn't it be better to run the intake tube through the radiator support and pick up cool air from behind the grill rather than from behind the radiator support?
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 06-20-2015, 04:23 AM
Sheck44's Avatar
Sheck44 Sheck44 is online now
Default cooler air
Agree with Steve ...
Built my own custom closeout / air box on the Pass side, and the entire filter is inside the fender
'Build it RIGHT the 2nd time'
69' SS X11 PRO-TOURING - SOLD
73' FJ40 LS - SOLD
1966 FJ40 R2.8 -SOLD
911 Hotrod - SOLD
2002 Gated 360
Next up - "Killer Piggy"
67' Camaro - Take-Over'
Old 06-21-2015, 02:05 PM
rallystyle rallystyle is offline
spectre did have a kit for the drivers side but looks like they are gone now. http://www.jegs.com/p/Spectre/Spectr...659/10002/-1l]
i think they are doing a redesign of the kit. i got one of there kits for my elcamino and its a nice kit. you can still get all the parts from them to make a intake. even the heat shield # 4377. i did see somewhere that some one called them and got the part # to make a kit. or airaid makes a kit to build one
https://www.airaid.com/f-body-intake-system.aspx hope that helps some.
1970 El camino
1969 camaro
1996 civic
Old 06-21-2015, 02:24 PM
This is something new coming out, Rotfab is supposed to be good but I don't know from experience. But probably not cheap.
http://www.camaro5.com/forums/showthread.php?t=411653
Old 06-23-2015, 10:18 AM
Swain's Avatar
Swain Swain is offline
I got a Spectre driver side kit, They are redesigning it so they sent me their first new one which I welded up for a cleaner look.
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 06-23-2015, 10:48 PM
SlowProgress's Avatar
Default Set me straight on braided hoses !
I am trying to figure out which hose system that Mark used in plumbing up the tank on Mayhem? It looks like a quality product and I want the black hose and fittings. I snooped around but could not figure it out. Anyone know for sure? There are a lot of choices out there now !
