Old 06-11-2015, 06:37 PM
I was mesmerized by the entire process....
What a "stud".
Old 06-11-2015, 06:41 PM
DFRESH's Avatar
DFRESH DFRESH is offline
What a "stud".
Wait till I start my "How I Detailed My Car" photo documentation series.
Old 06-11-2015, 06:43 PM
Make sure you watch Karate Kid a couple times -- so you get the "wax on, wax off" detail right.
Old 06-11-2015, 06:46 PM
DFRESH's Avatar
Sanda Flor----- Painta fence----
Rodger that GW.
D
Old 06-11-2015, 09:39 PM
Atta boy... It'll smoke Gordon and knock down 20 mpg.
Old 06-12-2015, 08:09 AM
Payton King's Avatar
Thanks for being the poster child for "what to do when buying a used motor." When you spend that kind of coin you really need to check everything regardless of who built it...valve spring and heads prove it!
Hurry up and get that bitch on the road, I want to be the only one left on jack stands...a man has to have a goal.
Old 06-12-2015, 08:16 AM
DFRESH's Avatar
As fast as my wallet will let me--
Old 06-12-2015, 10:39 AM
Just do what I do - I call The Bank of Charlie.... LOL
Old 06-13-2015, 08:34 AM
69hugger's Avatar
69hugger 69hugger is offline
Got just the T-Shirt for you when you're ready to shoot the video...
Bill
Bill
'69 Camaro / 534 BBC / DSE Built
'67 C10 / LS-3 w/Magnuson / Roadster Shop Chassis (SOLD)
'71 Blazer / LT4 / 8L90 / Roadster Shop Chassis / Ride Tech Air Susp.
Old 06-22-2015, 05:26 PM
DFRESH's Avatar
Wanted to show you guys a couple of pics of the Improved Racing Sump and Crank Scraper that I installed in the LS3 oil pan.
I had heard quite a few guys on the vette forum who recommended these for greater oil control for those who were road coursing or frequenting larger auto crosses.
It was 300 bucks, and came with new oil pan gasket, new oil pump ring gasket, the crank scraper, and finally the sump/trap door setup.
Here are a few pics of the install.
Here is the factory windage tray after pulling off the pan and the oil pump pickup tube.
[IMG][/IMG]
Ready for Crank Scraper
[IMG][/IMG]
Drop it over the studs and start measuring for clearance. I.R. calls for .020 to .060 of clearance to the crankshaft. It is clearly marked for orientation, and install is fairly straightforward.
[IMG][/IMG]
[IMG][/IMG]
Since this motor has aftermarket Crank, Rods & Bolts, I had a fair amount of filing/grinding on the crank scraper to achieve the necessary clearance.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
After everything was clearanced, I went ahead installed the sump and torqued down the studs for the final time.
[IMG][/IMG]
[IMG][/IMG]
Ready for the pan install.
