Old 06-30-2015, 06:08 PM
tmadden's Avatar
tmadden tmadden is offline
Looks great
Old 08-31-2015, 12:16 PM
jeds jeds is offline
Well...seeing as how I've been running this project without any REAL plan, I figured it would be good to get the direction hammered out. I ended up getting in touch with Ben Hermance a while back and decided to work with him on a rendering that I could stick to throughout the build. I desperately needed this to give me some sense of direction, otherwise I would keep changing things and continue wasting time and money.
I didn't give him much direction other than overall influence/theme, and that I wanted to finally get more rubber under a Nova (give me flares without ruining the car). I am more than pleased with the final out come. Eventually I'll need to find a shop that can take this on. I would like to stick to the PNW, but we'll see. Anyways....
Here it is. I welcome all feedback good or bad!
Old 08-31-2015, 02:05 PM
Dave95z28 Dave95z28 is offline
Originally Posted by jeds View Post
I've been exploring motor options still. These are the two starting points I've been looking at:
~11.5k. Mast black label ls3 416 long block. It comes with Callies H-Beam rods, Callies crank, diamond pistons, etc...
~7k. Lingenfelter 417 short block. It comes with Callies dragon slayer crank, JE pistons, Oliver I-beam rods.
I haven't seen what rods/crank mast is using as it is not specified. I assume compstar?
Is the extra cost worth it to start with the Lingenfelter short block?
Anyone have experience with either company?
You might check out options from SDPC. At one time they were offering LS3 based 396s and 427s for just under $8k for a long block. With the CNC LS3 GM Castings I think the 427 was rated at something like 615HP. They don't advertise them on their website. But they advertise them at the shows they attend and multiple vehicle forums every once in a while.
Dave
Old 08-31-2015, 10:03 PM
JayR JayR is offline
Lateral-G Supporting Vendor
Killer project and concept! You dove right in! JRod and Custom in Auburn (Lat-g screen name J-Rod&Custom) can handle anything you need from making the sheetmetal flares from scratch, bodywork and painting it, to plumbing and welding and whatever else you need but the interior. Check out the other Nova he built https://lateral-g.net/forums/showthread.php4?t=47552
Old 09-02-2015, 07:12 AM
Well...motor plans mellowed out for now. The boss convinced me to drive something more manageable to start out and "upgrade" later if I really feel the need. Motor showed up yesterday. Pretty simple LS3. About 550 fwhp.
Old 09-02-2015, 11:59 AM
Ketzer's Avatar
Ketzer Ketzer is offline
Love it!
Old 09-02-2015, 06:19 PM
Gas tank showed up after a bit of a snafu with a tank mixup. Ricks and MCB went above and beyond to fix the issue and the turn around was extremely quick. Both are top notch.
Old 09-02-2015, 11:46 PM
very nice!!! Yes, manageble is fun too.
A Wegner Black diamond cut LS drive system would look bad assss on that engine!!
Old 09-11-2015, 10:16 AM
For better or worse, I have new tires on the way....
Scrub radius should get interesting...Time to warm up the cutoff wheel and get ready to make some room!
Anyone need 2 19x11 Formula43 wheels?
Old 09-11-2015, 10:19 AM
98ssnova's Avatar
98ssnova 98ssnova is offline
Why did you change to a 18" wheel?
