Old 09-18-2015, 08:15 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
That's some good progress!!
Curtis
Old 09-18-2015, 08:25 AM
rickpaw rickpaw is offline
Ridetech installation. Had to narrow the 4-link bracket to fit between the replacement DSE frame rails
Also, wheels/tires showed up. 18x9 all the way around, with 255/40/18 front and 275/35/18 rear. Will have to mock up the rear wheels/tires and have the Ford 8.8 rear end narrowed to match.
Tu Ho
Old 09-18-2015, 08:26 AM
The trunk area around the fuel tank has some rust, so in the process of cutting out the rust and replace with fresh metal.
Tu Ho
Old 09-19-2015, 05:04 PM
Spent most of the day today cut out the rusted trunk panel and welded the replacement pieces.
Welded/painted.
Put up the rear wheels/tires to measure the rearend width.
Tomorrow I'll start cleaning up the rearend to get it ready for the rearend shop.
Tu Ho
Old 09-19-2015, 05:38 PM
Looking good!! That replacement sheet metal is garbage isn't it. The front trunk piece is even shaped wrong. I ended up bending it the other way so I could get to the upper coil over bolts.
Sits nice too!
Old 09-19-2015, 05:58 PM
jarhead's Avatar
jarhead jarhead is offline
Nice looking work!
joe
Semper Fi
My 68 Torino
Old 09-20-2015, 08:43 AM
Sits nice too!
Yeah, the replacement panels were junk, but close enough to make it work. I did not check the coil over bolts, will have to verify it today.
Originally Posted by jarhead View Post
Nice looking work!
Thanks.
Tu Ho
Old 11-20-2015, 07:55 AM
Well, a little more update on the Mustang.
Got the old 8.8 rearend out and removed all the unnecessary brackets.
IMG_0717 by Tu Ho, on Flickr
Got the Ridetech stuff installed after narrowed/rebuilt the rearend.
IMG_0783 by Tu Ho, on Flickr
Tu Ho
Old 11-20-2015, 07:58 AM
Got a little sidetracked on the car when my neighbor across the street came home with this.
IMG_0822
IMG_0821
IMG_0823
IMG_0823
Race Car Replica GT40 kit, configured for right hand drive.
Tu Ho
Old 11-20-2015, 08:02 AM
Started on Dynamat/insulating the car.
IMG_0875
IMG_0878
Welded studs on the firewall for the VA case.
IMG_0879
Running the lines for the AC
IMG_0900
IMG_0832
Drilled holes for the VA bulk head.
IMG_0833
Tu Ho
