Old 07-09-2015, 03:47 PM
I have a brand new PSI LS3 / T56 magnum harness on the shelf if you need it.
I didn't see that on your web site Ron?
Whats my dealer price?
Old 07-09-2015, 05:30 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
You don't need to shorten, cut or re pin to do the job.
This is my new build in progress. The fuse box is mounted behind the pass headlight and all wire bundles are securely tucked in the inner fender along with the AC and heater hoses.
The sensor wires will be folded into power braid to the proper length
Old 10-03-2015, 09:24 AM
droptop 63 droptop 63 is offline
Beautiful detail. My problem is space under the dash on a 63 nova once you try to make the Vintage Air box fit in the same space on the firewall. Any suggestions??
Old 10-03-2015, 09:44 AM
ADiCarlo ADiCarlo is offline
I vote for PSI I know and have seen a ton of people running their stuff.
Old 11-01-2015, 09:50 AM
alongfortheride alongfortheride is offline
I have not ran psi. I have now ran 2 Speartech units. 1 ls1 t56 and 1 lsa856. I must say the Speartech stuff is very nice. He will make it what ever length you would like. John is great.
Old 11-14-2015, 02:54 PM
cpd004's Avatar
cpd004 cpd004 is offline
I've had both PSi and Speartech...the Speartech is the nicer looking of the 2 and seems to be better built. I could be wrong, though. It's cost is much higher. The braiding they use is the softer material making to easier to tuck in and around things compared to the corrugated stuff. There wires seem to be more pliable. Also, Speartech provides provisions for AC and cruise control. Their fuse panel is less bulky and no need to run wires down to the starter like with PSi.
Both companies are always quick to provide tech support.
I have no experience with a GM harness, but if I already had one....I'd definitely use it and spend money somewhere else. Something always comes up that you didn't expect.
BTW Vegas...that engine bay looks great!
1971 Firebird
2017 SS
Old 11-14-2015, 05:53 PM
randy randy is offline
my harness is complete and i second this. Hardest part is finding room to mount the fuse box and ecm
Old 11-16-2015, 03:01 PM
Revved's Avatar
Revved Revved is offline
Getting ready to start my first LS376/4L65E / Detroit Speed Swap into an 80 Trans am... I've got the whole GMPP Package and I'm looking at those miles of wires and getting my solder and shrink wrap ready!!
-Sean
Comp Performance Group
Business Development Manager
1970 Chevelle I built years back as a Lat-G Feature https://lateral-g.net/forums/showthread.php4?t=43116
Old 11-16-2015, 03:44 PM
Vega$69's Avatar
No reason to solder anything unless you are extending the wire lengths
Old 11-16-2015, 05:43 PM
yes i didn't solder anything either. Everything on the gmpp unit is plug and play. i had to change the vss connector for the t56 magnum but that was it. Now the american autowire kit is a diff story. I didn't solder anything there either though
there will be a lot of wires that you will not use if you are using the gmpp kit. I made this and helped a lot
