Old 11-23-2015, 10:32 AM
Brown's Classics's Avatar
Brown's Classics Brown's Classics is offline
Default Brown's RY427 Mustang Fastback Build
New project in the shop we are building. Its a 1965 Mustang Fastback with plenty of modifications coming its way with the biggest one being the first ever Roush Yates FR9 Based Nascar engine in a street car that will make 850 hp at 9000 rpm. Here are some photos of what we are starting with and the Rendering.
Old 11-23-2015, 02:41 PM
preston preston is online now
Looks good. That looks like a real nice survivor car, I used to be the last person to every say this but almost sad you're going to cut it up.
Engine should be fun but I have my doubts you will be happy running the 9000rpm cam on anything approaching a street vehicle. Most people I have seen over the years that put Nascar engines in always end up dialing back the cam quite a bit, but I wish you luck. Can't wait to see you package in something approaching a modern Nascar header too.
Only other thought is the rendering shows the lower valence closed up, you will probably want to open that up for more cooling flow.
Also, post it under the sub-forum "Project Updates" where we can follow along.
Old 11-24-2015, 01:18 AM
JB400's Avatar
JB400 JB400 is offline
I agree that it's too nice to "cut up", but it's a nice project idea. I'd almost consider looking for just a shell, unless this car is non numbers matching.
Old 11-24-2015, 09:14 AM
syborg tt's Avatar
syborg tt syborg tt is online now
Great looking project and one that I am looking forward to watching.
marty-mj
Old 11-24-2015, 10:32 AM
Preston- it is a very nice car to start with. Basically zero rust. It was a "c" code matching numbers car. Couple issue that we will fix along the way but overall the car isn't going to get massively modified on the exterior, just cleaned up. As far as the engine goes, that's what will make this car special. Roush Yates is developing a custom engine specifically for the street. It will idle at about 1000-1200 rpm and start making power at 2-2500 all the way to 9k. Some of the things they are going to be doing is what will make it possible to drive this in normal conditions.
Old 11-24-2015, 03:53 PM
Cool project.
I am dying to see some specs on a Nascar based motor that idles at a grand, has great low end and pulls to 9000.
Old 11-24-2015, 07:28 PM
Cool project.
Trust me. I am too. The engineering that they are putting in to this motor is incredible. I will update on the build tomorrow.
Old 11-24-2015, 11:22 PM
Originally Posted by Brown's Classics View Post
Any chance a mod could fix my spelling in the title?
Done. It happens.
Old 11-25-2015, 08:06 AM
Welcome to the site. Sounds like it's going to be a great build. Good luck!
Old 11-25-2015, 08:08 AM
Back from the blaster.
They are never as clean as you hope but this one is still pretty solid. It had not been registered since 71 and is still a california black plate car (which we intend to keep it that way). Must of been hit in the late 60's and had a quarter slapped on it. we will be replacing the damaged sheet metal as we go.
