Originally Posted by ctcz28
I know this is an older thread, but I thought I'd add the information I recently (Oct. '15) received from Tremec when I asked them the same question. The answer was Mobil 1 Synthetic ATF. In my question to Tremec (via the tech line on their webpage) I referenced the recommendations for Dextron III and Pennzoil Synchromesh and even asked if I should break in the T56 with the Dextron and then switch to something else or stay with the Dextron and Tremec clearly stated in its reply that " the correct fluid for your Magnum transmission is Mobil 1 Synthetic ATF".
IMHO, those guys at Tremec are yahoos and don't know anything other than how to write up a sales invoice. I called them a while back about bellhousing alignment and they told me its not required, but if I wanted to....following these directions (which were for the 4 speed bellhousing). Told him about removing the front plate and he proceeded to tell me not to take the transmission a part.
