Old 01-07-2016, 10:48 PM
awr68's Avatar
awr68 awr68 is offline
Default VA low mount AC?
I have a 68 Camaro with a SpeedTech frame. I would like to use a fbody accessory bracket for PS and Alt but really don't care for the look of a high mount AC compressor even with the Holley bracket. Has anyone tried Vintage Air's Low Mount bracket? And would a SD7 be better than the 508 for fitment?
The VA low mount looks similar to what Mark fabbed up on Camaro X so I have hopes it may work. I'm thinking using a SD7 will help with plumbing since it from the from the side and not out the back like on the 508.
I love the Front Runner or Drive Junky but not sure it's in the budget. I may just have to use Holley's brackets.
Tony
'68 Camaro
Old 01-08-2016, 03:45 PM
gray86hatch gray86hatch is offline
http://www.alangrovecomponents.com/LS.htm
86 mustang
454 lsx FTI ls3 mast 4500 9.24 144 pump gas dragradials
79 z28 29k org miles. DSE suspension Bonspeed GTB
Old 01-08-2016, 04:27 PM
awr68's Avatar
Originally Posted by gray86hatch View Post
Thanks! That looks like the same approach as the VA low mount. Do you know for sure this will work for my application?
Tony
'68 Camaro
Old 01-08-2016, 04:41 PM
Can't answer if it will clear your subframe. Allows the va comp to be used in stock location so you don't have to use a gm comp
Tim
86 mustang
Old 01-10-2016, 06:55 PM
alongfortheride alongfortheride is offline
Is this there new extreme chassis or there older chassis
Old 01-13-2016, 09:55 AM
rjsjea's Avatar
rjsjea rjsjea is offline
I just put the AlanGrove mount on an LS1, cant tell ya if it will work on your chassis. It mounts the SD508 nice and tight to the block. I'll snap a pic if you would like?
RobS
71 Demon, AlterK - 4 link GenIII hemi conversion
66 Rambler Classic Wagon, LS conversion -Scott's IFS/4bar-bagged
Old 01-13-2016, 11:13 AM
awr68's Avatar
Pic would be great! Thanks!
Tony
'68 Camaro
Old 01-13-2016, 11:14 AM
awr68's Avatar
It's the older one.
Tony
'68 Camaro
Old 01-14-2016, 03:04 AM
sleepertime's Avatar
sleepertime sleepertime is offline
Post
I used the Allen Grove low mount for the camaro. I am very happy with results. Nice and tight.
My build BRNAGN 1969 camaro SS
Old 01-14-2016, 09:30 AM
TomM's Avatar
TomM TomM is offline
Here is the Alan Grove bracket with a Sanden 508 on an LSA motor in a 66 Nova....the Vintage Air bracket IS an Alan Grove bracket.
https://lateral-g.net/forums/show...t=50955&page=5
Post #49....
T,
