Old 02-05-2016, 11:15 AM
anarchy99 anarchy99 is offline
Default Trans to rearend... No room for driveshaft...
So I'm trying to measure for an engine trans swap and cutting, welding, etc isn't the issue, it's, well... The tail shaft of the trans I was thinking of using basically would be real real close to the rear end. No room for a drive shaft. I think the cheetah car was directly bolted to the rear from the trans, so I'm pretty sure it's been done before, and if this isn't the right forum, please move me around... But what would needed to be done, solid motor mounts and an independent rear setup? Should that make it all work and allow room for flex under acceleration, etc? A single joint linking both yokes? Thanks in advance.
Old 02-05-2016, 12:23 PM
z28cp z28cp is offline
If you're not willing to move the engine/trans forward, you're pretty much stuck going independent. I single u-joint won't allow a solid axle to move up and down.
Old 02-05-2016, 12:26 PM
Yeah, that's actually moving the engine back far enough to clear everything up front... I'd go manual trans but moving the engine back cuts down the footbox a lot.
Old 02-08-2016, 12:29 PM
BMR Sales's Avatar
Here's a Cheetah set-up
