Old 03-08-2016, 07:28 PM
1in1969 1in1969 is offline
Thumbs up
Some How I kinda figured that! Nice cars you have Ken
Old 03-08-2016, 08:50 PM
Originally Posted by kwhizz View Post
There's always one more........It just hasn't showed up............Yet !!!!
You can fly east for three hots and a cot to help kick my butt in gear! lol It's looking real good buttoned up .
Old 03-09-2016, 07:55 AM
CarlC CarlC is offline
Ken, if you need any parts for extending the wiring and hose for the fuel pump let me know.
http:www.vaporworx.com
Old 03-09-2016, 10:12 AM
kwhizz's Avatar
kwhizz kwhizz is offline
Thanks............
But I think I will be fine (those famous last words)
Ken
Old 03-10-2016, 11:03 PM
Thanks............
Ken
Been there.....
We have weld-in mounting rings as well that use the GM cam ring and o-ring seal.
https://www.vaporworx.com/product/gm5ss/
Old 03-11-2016, 04:31 AM
kwhizz's Avatar
Been there.....
Yep.......I already have one of your weld in flanges
Old 03-16-2016, 02:35 PM
kwhizz's Avatar
Well........The last big hurdle is the Fuel system......Two issues here.......#1....The Nomad gas tank is nothing like a stock 57 tank......with the spare tire well in the rear floor....there wasn't too much room left for a gas tank.....so GM pretty much form fit a tank in the space that was available......as you can see........
And a new tank I bought for Modifications.............
I'm using a GM LSA Fuel pump which is 7 1/2" high and the Nomad tank is 12" deep.....So......two problems....the GM pump needs to be spring loaded against the bottom of the tank......so...I need to build a recessed mounting system for the GM pump......and I need to lengthen the stock LSA pump to replicate the stock compressed GM specs......Here are some pic's of the Tank Modifications.......Should be finished later this week........
More to come
Old 03-16-2016, 02:50 PM
kwhizz's Avatar
Also..........To get the old Nomad tank out of the car I basically had to just about take the rear axle assy out........I disassembled everything and slid the housing forward on the springs to get enough room for the tank to come out.......And....as long as I am ripping the rear of the car apart, I had an Axle oil seal leak on the passenger side, so....pulled the axle out to get that fixed.......then I checked and found out the rear was an open rear......so....pull it all apart and took the third member to get a Posi unit installed.........used a couple cans of Brake clean to get the oil out of the parking brake assy and to get the pads and rotors cleaned up......should have the rear ready for reassembly when the tank is finished.....
Old 03-16-2016, 03:15 PM
kwhizz's Avatar
And........The Fuel pump.........A couple of concerns here.......The GM pump has exposed wires that are submersed in the gasoline........So....I found out by asking the experts on LS1tech how to extend the wires while lengthening the pump......I was told to use PTFE wire and shrink tubing only.......took a while to locate the Teflon insulated wire and shrink tubing......finally got everything and got the wires fixed.........next was the flexible "Soda Straw" feed line from the pump to the outlet port on top of the assy........couldn't figure out a good way to lengthen the corrugated plastic tube without crushing or restricting the line........so.....I ended up getting some -8 braided stainless fuel hose and it worked out perfectly......I cut off the plastic tube and left the stock GM RF sealed tube ends on the fittings.....the -8 hose fit over these tube ends perfectly and will be held on with stainless hose clamps.....then I made some stainless rod extenders and longer springs to make the pump to the new length.........all finished, just need to wire tie the wires to neaten then up.......
Old 03-16-2016, 04:34 PM
That looks like a nice fix Ken.
