Old 04-18-2016, 11:24 PM
John510's Avatar
John510 John510 is offline
Default Remote battery charging terminals
Does anyone have remote battery charging terminals? Getting my battery out of the trunk is a PITA. If so where did you install them? Pics? Or maybe a battery cut off switch? I need one of these.
John
[SIGPIC][/SIGPIC]
Old 04-19-2016, 07:30 AM
clill's Avatar
clill clill is offline
Why not just add the wire pigtail that comes with most trickle chargers ?
Old 04-19-2016, 07:55 AM
Ring brothers , Eddie Motorsports, feeler lots of companies make and sell nice charging ports . I'd agree with the trickle charger set up thou. My buddy has them on his cars and toys ....easy to tuck the lead out of the way.
Old 04-19-2016, 09:02 AM
John510's Avatar
Didnt know they came with those. I will be ordering an Optima charger today Thanks
[SIGPIC][/SIGPIC]
Old 04-19-2016, 09:37 AM
clill's Avatar
I love my Ctek charger. Charges Optima batteries that my Optima charger says can't be charged.
http://car-battery-charger-review.to...ek-review.html
Old 04-19-2016, 01:01 PM
HotRod68Camaro's Avatar
HotRod68Camaro HotRod68Camaro is offline
Same here, i have multiple.
Kyle
Old 04-19-2016, 02:26 PM
Try2paz's Avatar
Try2paz Try2paz is offline
I've not been a fan of any of the Optima products since they were sold.
I used a trickle / float chargers recently from Optima and was frustrated with it more than anything else. It would take 15 mins to "analyze" the battery.
Id save $100 bucks and get the CTEK.
1967 Nova
2018 Camaro ZL1 1LE
Old 04-19-2016, 02:38 PM
randy randy is offline
https://www.facebook.com/photo.php?f...type=3&theater
Do this
Old 04-19-2016, 03:30 PM
66fury's Avatar
66fury 66fury is offline
i put a shut off and some battery lugs up under my rear bumper so i can hook up a trickle charge to my battery while keeping car shut off from power when not in use.
mark
Old 04-19-2016, 04:42 PM
Just to add my cents here ---- there's a HUGE difference between being able to "trickle" charge your PITA battery location - and being able to get a JUMP to that battery if needed.... and when it's needed it's never when your hanging out in your nice dry garage.
Remote battery JUMPER studs can be used to hook a trickle charger (I also vote for Ctek - they're the best period) - so if you're planing on something farirly permanent - this is an alternative.
There's MANY ways to mount these - and just as many locations....
http://www.summitracing.com/parts/sum-g1430/overview/
In a 55 Post I built for a buddy - I made a nice spot in the trunk for a cutoff switch and the posts - which was then upholstered over with a nice access panel.
And yes --- before it was finished up and installed for the last time - the red was changed out for a black (so one of each) but at the time of the build I was using what I had laying around for mock up....
By the way -- With the new electronics all having memory now that needs constant power -- I alway put a 3 or 5 amp fuse across the switch terminals so there's power even with the switch turned off. It's enough to run the memory and obviously not enough to start the car! LOL
