Old 04-25-2016, 05:44 AM
paulk68 paulk68 is offline
Default Which LS engine lift plate?
looking for recommendations on LS lift plates let me know which one you guys like.
Old 04-25-2016, 07:29 PM
gray86hatch gray86hatch is offline
I have one I build that allows the valley cover to stay on and also works with a 4150 and 4500 manifold
Tim
86 mustang
454 lsx FTI ls3 mast 4500 9.24 144 pump gas dragradials
79 z28 29k org miles. DSE suspension Bonspeed GTB
Old 04-25-2016, 07:56 PM
86 mustang
Old 04-25-2016, 10:15 PM
1965_SS's Avatar
1965_SS 1965_SS is offline
I used a Jegs engine lift plate, #80093
_________
1965 Chevelle SS
Project Build
Old 04-26-2016, 09:33 AM
toddoky toddoky is offline
I use the adjustable one from Mac's...the adjustable feature alone is worth the cost in my opinion.
Old 04-26-2016, 10:04 AM
Thats the same one I have, it's made for the LS it mounts to the exhaust bolts so no need to remove the intake. Expensive but the tilt adjusts really easy.
Old 04-26-2016, 04:54 PM
Thanks guys I will explore those options. I appreciate the help
Old 04-26-2016, 06:03 PM
I'be used it in that manner and also by removing the tilt mechanism from the tube frame and attaching it directly to the valley cover on top of the engine.
Old 04-27-2016, 08:07 PM
Nine Ball Nine Ball is offline
The type that bolt onto the valley cover are better, because you can pull or drop an entire engine without removing the hood. I used the one from Quick Time Performance, and it balanced nicely with the front belt accessories and clutch/flywheel installed. Got it from Summit.
Founder, LS1Tech.com
1969 Camaro SS Convertible | 1970 Chevelle SS 454 | 2006 Viper Coupe | 2014 Viper TA | 2014 Camaro SS 1LE
Online Garage: www.fquick.com/NineBall
Old 05-21-2016, 11:55 AM
Nine Ball, I used the one I have because I didn't want to remove the supercharger. I would have been much happier to use one like you did if the intake was coming off.
