Old 07-05-2016, 10:47 PM
64mali's Avatar
64mali 64mali is offline
Default T56 electrical connections?
Can anyone tell me what these plugs are? I think the one on the other side is for reverse lights correct?
Old 07-06-2016, 04:25 AM
130fe 130fe is offline
I am pretty sure the one on the left is the skip shift switch (pink/green) and the VSS is on the right (purple/yellow). The reverse lockout solenoid is the one above the VSS, the round cylinder type switch. The reverse light switch is on the pass side. What is the trans out of?
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 07-06-2016, 01:33 PM
64mali's Avatar
Thank you. 2002 Camaro. Is VSS the speedometer sensor? If so, do I hook it straight up to the Dakota Digital box?
Old 07-06-2016, 02:01 PM
Yes VSS is for the speedo. Wiring info above is right.
Dakota digital should have some information on how to wire that up. I know my American Autowire update harness had wiring specifically for the VSS and for the connection to an electronic speedo.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 07-06-2016, 02:33 PM
64mali's Avatar
Perfect, thanks guys
Old 07-06-2016, 03:50 PM
What engine are you running?
Chris
1968 Camaro SS
LS3/T56
Old 07-07-2016, 10:29 PM
64mali's Avatar
468 Bbc
